Trouble Streaming Fonera 2.0n webcam to ZM
Posted: Wed May 25, 2011 5:26 pm
I am trying to stream video from a webcam attached to my Fon 2.0n router using the latest Fonera firmware. As some may know that this excellent piece of hardware has a USB port and software (cambozola) to utilize the USB port for streaming. I have retrieved the path the stream uses however, it changes every time I log in and out of the router. Is there a work around to get ZM to see this path change? The path is:
<IP of Cam>/luci/;stok=XXXXXXXXXXXXXXXXXX/fon_devices/fon_webcam
The stok=XXXXXXXXXXXXXXXXXX is the only part of the path that changes, the rest is static. I have tried to put username:password@host_ip (with my specific parameters) in the host path of a remote cam inside of ZM but that does not help. Any advice? Is this a restriction within the stock Fon firmware? Would installing different firmware on the router solve this issue?
Thanks in advance.
Thanks in advance.
