Update of ZoneMinder clears database!
Posted: Fri May 27, 2011 7:12 pm
Why is this?
Now everything including configs is gone
store-server:/usr/src # zypper up ZoneMinder-MP
Loading repository data...
Reading installed packages...
Resolving package dependencies...
The following NEW packages are going to be installed:
php5-zip zip
The following package is going to be upgraded:
ZoneMinder-MP
1 package to upgrade, 2 new.
Overall download size: 936.0 KiB. After the operation, additional 430.0 KiB will be used.
Continue? [y/n/?] (y): y
Retrieving package zip-2.32-83.1.x86_64 (1/3), 116.0 KiB (348.0 KiB unpacked)
Retrieving: zip-2.32-83.1.x86_64.rpm [done]
Installing: zip-2.32-83.1 [done]
Retrieving package php5-zip-5.3.3-0.17.1.x86_64 (2/3), 39.0 KiB (85.0 KiB unpacked)
Retrieving: php5-zip-5.3.3-0.17.1.x86_64.rpm [done]
Installing: php5-zip-5.3.3-0.17.1 [done]
Retrieving package ZoneMinder-MP-1.24.2-11.1.x86_64 (3/3), 781.0 KiB (5.1 MiB unpacked)
Retrieving: ZoneMinder-MP-1.24.2-11.1.x86_64.rpm [done (209.6 KiB/s)]
Installing: ZoneMinder-MP-1.24.2-11.1 [done]
Additional rpm output:
warning: /etc/zm.conf created as /etc/zm.conf.rpmnew
Starting SuSEconfig, the SuSE Configuration Tool...
Running module permissions only
Reading /etc/sysconfig and updating the system...
Executing /sbin/conf.d/SuSEconfig.permissions...
Checking permissions and ownerships - using the permissions files
/etc/permissions
/etc/permissions.easy
/etc/permissions.d/ZoneMinder-MP
/etc/permissions.d/ZoneMinder-MP.easy
/etc/permissions.d/mail-server
/etc/permissions.d/postfix
/etc/permissions.local
setting /usr/bin/zmfix to root:www 4755. (wrong owner/group root:root permissions 0755)
Finished.
..failed
insserv: script jexec is broken: incomplete LSB comment.
insserv: missing `Required-Stop:' entry: please add even if empty.
store-server:/usr/src # /etc/init.d/zm stop
run zm_database_init first to create/update zm database
Shutting down ZoneMinder Daemon done
store-server:/usr/src # /etc/init.d/zm start
Starting ZoneMinder Daemon failed
store-server:/usr/src # zm_database_init
INFO: when db is correctly installed and you just reinstalled rpm, then answer all questions with 'n'
new install create db
run mysql command to create db as user root? [Y/n]: y
create user zm_admin for zoneminder? [Y/n]: n
removing lock file
done
Starting ZoneMinder Daemon done
