Recording outside of working directory
Mad Professor
Post by Mad Professor »
Good Day All.
Can someone please advice me to what would be the best way to Record outside of the zoneminder default folder?
My current setup records eveything to "/var/cache/zoneminder/events"
I have just fitted a new HDD, and it is mounted to "/media/CCTV"
So I no longer what to record to "/var/cache/zoneminder/events" but instead record it to "/media/CCTV".
What is the best way to do this?
Thanks for your time.
Best Regards.
DREMA
Re: Recording outside of working directory
Post by DREMA »
Just create a symlink to your new directory.
Backup you original event folder
$ mv /usr/share/zoneminder/events /usr/share/zoneminder/eventsbackup
Create the symlink
$ ln -s /media/CCTV /usr/share/zoneminder/events
Check the directory
ls -hal /usr/share/zoneminder/
events should point to /media/CCTV
One thing, just be careful on not starting zoneminder with your harddrive unmounted, because zm run a consitensy check every few minutes, and if your directory is not present, zmaudit.pl won't find the files and it'll delete the events from the database.
Just... enjoy life! :D
zoneminder
Site Admin
Post by zoneminder »
I think
ls -n
probably should be
ln -s
:lol:
Phil
DREMA
Post by DREMA »
Hahaha right, damn dyslexia.
Corrected.
Mad Professor
Thanks for your replies.
I am now trying to hardlink zoneminder to my spare drive.
Here is what I have put in my "/etc/fstab"
/dev/sdb1		/media/CCTV			ext4	defaults	0	2
/media/CCTV/images	/var/cache/zoneminder/images	none	defaults,bind	0	2
/media/CCTV/events	/var/cache/zoneminder/events	none	defaults,bind	0	2
/media/CCTV/temp	/var/cache/zoneminder/temp	none	defaults,bind	0	2
Now when I load the ZoneMinder front page is shows "Disk: -1%" and will not record to disk.
I guess I have missed something, can you please advice.
Flasheart
Post by Flasheart »
Read http://www.zoneminder.com/wiki/index.ph ... Hard_Drive
Symlinks are not detected by the debian installer packages, so will be removed and recreated. zmaudit will then not be able to find the files and will kill all the events in your database.
If using debian or ubuntu, do not use symlinks for this!
