ZM doesnt open anything larger then 800X600
Posted: Thu Jun 02, 2011 1:43 am
Hello guys i was using zm with 640x480 cameras and they do work fine.
Now i just got Toshiba ik-wr12a capable of 1600x1200 (i dont think it has mpeg support so i am using still images )
but if i set up resolution higher then 800X600 zm doesn't like the source. To make sure it is not camera causing the issue i uploaded single image(different resolutions) to a web server, but still once i point zm to anything higher then 800x600 it doesn't work. Any ideas.
Is there a log file that i can look at/post here. Thank you.
