Page 1 of 2
Zoneminder 1.24.3/1.24.4 on Fedora 15
Posted: Fri Jun 03, 2011 11:12 pm
by danodemano
Good evening all!
Last night I needed to scratch and itch and upgrade my Fedora 14 box to Fedora 15. For the most part the upgrade went well but I have a few things that need worked out, Zoneminder being one of them.
On Fedora 14 I had installed the ZoneMinder RPM from RPMFusion and this worked great. When the box upgraded it did upgrade ZoneMinder as well to version 1.24.3 (it was running 1.24.2) but the install seems broken. I am unable to start the zoneminder service from /etc/init.d/zoneminder and can find almost zero logs. I get this in the /var/log/messages:
Jun  3 18:56:22 fedoraserver systemd[1]: zoneminder.service: control process exited, code=exited status=255
Jun  3 18:56:22 fedoraserver systemd[1]: Unit zoneminder.service entered failed state.
and this if I do a '/etc/init.d/zoneminder status' but nothing else useful.
[root@fedoraserver ~]# /etc/init.d/zoneminder status
zoneminder.service - SYSV: ZoneMinder is the top Linux video camera security and surveillance solution. ZoneMinder is intended for use in single or multi-camera video security applications.Copyright: Philip Coombes, Corey DeLasaux 2003-2008
	  Loaded: loaded (/etc/rc.d/init.d/zoneminder)
	  Active: failed since Fri, 03 Jun 2011 16:44:23 -0400; 1h 42min ago
	 Process: 25719 ExecStart=/etc/rc.d/init.d/zoneminder start (code=exited, status=255)
	  CGroup: name=systemd:/system/zoneminder.service
Bareword "PROT_READ" not allowed while "strict subs" in use at /usr/share/perl5/vendor_perl/ZoneMinder/Memory/Mapped.pm line 91.
Bareword "PROT_WRITE" not allowed while "strict subs" in use at /usr/share/perl5/vendor_perl/ZoneMinder/Memory/Mapped.pm line 91.
Bareword "MAP_SHARED" not allowed while "strict subs" in use at /usr/share/perl5/vendor_perl/ZoneMinder/Memory/Mapped.pm line 91.
Compilation failed in require at /usr/share/perl5/vendor_perl/ZoneMinder/Memory.pm line 120.
Compilation failed in require at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 37.
BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 37.
Compilation failed in require at /usr/bin/zmpkg.pl line 46.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 46.
ZoneMinder is stopped
I then though well I will just build ZoneMinder 1.24.4 from source and go that route, but it won't even build properly. When I do the ./configure that works but when I do a make install (WITHOUT ffmpeg) it bombs:
In file included from zm_mpeg.h:23:0,
                 from zm_stream.h:27,
                 from zm_event.h:39,
                 from zm_zone.h:27,
                 from zm_monitor.h:26,
                 from zmc.cpp:28:
zm_ffmpeg.h:33:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55:2: error: #error "No location for swscale.h found"
In file included from zm_stream.h:27:0,
                 from zm_event.h:39,
                 from zm_zone.h:27,
                 from zmc.cpp:28:
zm_mpeg.h:43:7: error: use of enum ‘PixelFormat’ without previous declaration
zm_mpeg.h:44:2: error: ‘AVOutputFormat’ does not name a type
zm_mpeg.h:45:2: error: ‘AVFormatContext’ does not name a type
zm_mpeg.h:46:2: error: ‘AVStream’ does not name a type
zm_mpeg.h:47:2: error: ‘AVFrame’ does not name a type
zm_mpeg.h:48:2: error: ‘AVFrame’ does not name a type
make[1]: *** [zmc.o] Error 1
Any help tracking down the problem(s) would be greatly appreciated cause I have had zero luck finding anything useful....and I don't really know where else to look. Thanks so much!!!
Re: Zoneminder 1.24.3/1.24.4 on Fedora 15
Posted: Sat Jun 04, 2011 1:49 am
by cordel
Fedora has gone strait to using system unit and dropped the sysV startscripts.
I'll be working on a new Unit start script for ZM shortly.
Mean time you can start manually with zmpkg.pl start.
Posted: Sun Jun 05, 2011 1:22 am
by danodemano
Thanks so much for the quick reply! I tried what you suggested however and it doesn't seem to work:
[root@fedoraserver init.d]# /usr/bin/zmpkg.pl start
Thanks again.
Posted: Mon Jun 06, 2011 3:05 am
by cordel
Check and make sure your database is running.
Posted: Mon Jun 06, 2011 11:12 am
by danodemano
The MySQL service? Yes, it's running:
[root@fedoraserver ~]# service mysqld status
mysqld.service - LSB: start and stop MySQL server
          Loaded: loaded (/etc/rc.d/init.d/mysqld)
          Active: active (running) since Thu, 02 Jun 2011 21:22:41 -0400; 3 days ago
        Main PID: 1814 (mysqld)
          CGroup: name=systemd:/system/mysqld.service
                  â 1465 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/my...
                  â 1814 /usr/libexec/mysqld --basedir=/usr --datadir=/var/...
I don't have any trouble logging into the ZoneMinder web interface either. It just says the service is stopped at the top and I can't start it:
ZoneMinder Console - Stopped - v1.24.3
Thanks again!
Posted: Tue Jun 07, 2011 8:51 am
by kolaCZek
Same problem on Fedora 15.
[root@pimserver ~]# /usr/bin/zmpkg.pl start
What to do? Help please... :cry:
Posted: Sat Jun 11, 2011 8:56 pm
by RuZa
Try it in a file /usr/share/perl5/vendor_perl/ZoneMinder/Memory/Mapped.pm
at the beginning of line 27 to put #
#use strict;
Posted: Tue Jun 21, 2011 12:09 am
by danodemano
Great idea, but no go:
[root@fedoraserver ~]# /usr/bin/zmpkg.pl start
There is no error on the command line but this is in /var/log/messages:
Jun 20 20:06:40 fedoraserver zmpkg[11115]: INF [Command: start]
Jun 20 20:06:40 fedoraserver zmfix[11124]: ERR [Config mismatch, expected 197 items, read 183. Try running 'zmupdate.pl -f' to reload config.]
Jun 20 20:06:40 fedoraserver zmpkg[11115]: ERR [Unable to run "sudo -u apache /usr/bin/zmfix", output is ""]
I was afraid to run that command as I didn't know what it did. Will running this let the service start?
Posted: Tue Jun 21, 2011 1:46 am
by KeithB
I've not quite got it working on F15 yet but the compile errors you received are all fixed by putting
CFLAGS=-D__STDC_CONSTANT_MACROS
into the zoneminder ./configure parameters
Posted: Tue Jun 21, 2011 2:42 pm
by zoneminder
I have done trial builds on Fedora 15 without any issue so am curious as to what is causing these problems. Are you running 32 or 64 bit?
Even though Fedora 15 has gone to systemd the existing sysv init scripts appear to still work as well.
Posted: Tue Jun 21, 2011 5:41 pm
by danodemano
I'm running 64bit. It was an upgrade from Fedora 14 so maybe that has something to do with it?
Posted: Tue Jun 21, 2011 6:13 pm
by KeithB
kolaCZek wrote:Same problem on Fedora 15.
In perl5/vendor_perl/ZoneMinder/Memory/Mapped.pm
change
my $mmap_addr = mmap( $mmap, $size, PROT_READ|PROT_WRITE, MAP_SHARED, \*MMAP );
to my $mmap_addr = mmap( $mmap, $size, *PROT_READ|*PROT_WRITE, *MAP_SHARED, \*MMAP );
That should at least get zoneminder to start.
Posted: Tue Jun 21, 2011 6:21 pm
by danodemano
Still no dice:
Jun 21 14:18:49 fedoraserver zmpkg[11612]: INF [Command: start]
Jun 21 14:18:50 fedoraserver zmfix[11621]: ERR [Config mismatch, expected 197 items, read 183. Try running 'zmupdate.pl -f' to reload config.]
Jun 21 14:18:50 fedoraserver zmpkg[11612]: ERR [Unable to run "sudo -u apache /usr/bin/zmfix", output is ""]
Jun 21 14:18:53 fedoraserver zmpkg[11623]: INF [Command: status]
Jun 21 14:19:46 fedoraserver zmpkg[11644]: INF [Command: start]
Jun 21 14:19:46 fedoraserver zmfix[11653]: ERR [Config mismatch, expected 197 items, read 183. Try running 'zmupdate.pl -f' to reload config.]
Jun 21 14:19:46 fedoraserver zmpkg[11644]: ERR [Unable to run "sudo -u apache /usr/bin/zmfix", output is ""]
Jun 21 14:19:48 fedoraserver zmpkg[11680]: INF [Command: status]
I tried it both ways with the use strict; commented out and with it uncommented and it throws the above error either way.
Posted: Tue Jun 21, 2011 9:38 pm
by zoneminder
Have you tried actually running 'zmupdate.pl -f' as it suggests? It should do it automatically when you run zmpkg.pl but you can do it manually as well.
Posted: Tue Jun 21, 2011 9:46 pm
by danodemano
I hadn't because I didn't know what it did but I just ran it and the service appears to have finally fired up:
[root@fedoraserver ~]# /usr/bin/zmpkg.pl status
running
Seems to be running fine also, I can see my video. I wasn't sure about this error though if it was anything to worry about, ERR ['zmwatch.pl ' exited abnormally, exit status 9:
Jun 21 17:43:02 fedoraserver zmpkg[3485]: INF [Command: start]
Jun 21 17:43:02 fedoraserver zmfix[3494]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03494]
Jun 21 17:43:02 fedoraserver zmfix[3494]: INF [Resetting permissions on /dev/video0 to 20666]
Jun 21 17:43:02 fedoraserver zmdc[3499]: INF [Server starting at 11/06/21 17:43:02]
Jun 21 17:43:05 fedoraserver zmdc[3499]: INF ['zmc -d /dev/video0' starting at 11/06/21 17:43:05, pid = 3523]
Jun 21 17:43:05 fedoraserver zmdc[3523]: INF ['zmc -d /dev/video0' started at 11/06/21 17:43:05]
Jun 21 17:43:05 fedoraserver zmc_dvideo0[3523]: INF [Debug Level = 0, Debug Log = <none>]
Jun 21 17:43:05 fedoraserver zmc_dvideo0[3523]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03523]
Jun 21 17:43:05 fedoraserver zmc_dvideo0[3523]: INF [Starting Capture]
Jun 21 17:43:05 fedoraserver zmc_dvideo0[3523]: WAR [Hue control is not suppported]
Jun 21 17:43:06 fedoraserver zmdc[3499]: INF ['zmfilter.pl' starting at 11/06/21 17:43:06, pid = 3528]
Jun 21 17:43:06 fedoraserver zmdc[3528]: INF ['zmfilter.pl' started at 11/06/21 17:43:06]
Jun 21 17:43:06 fedoraserver zmdc[3499]: INF ['zmaudit.pl -c' starting at 11/06/21 17:43:06, pid = 3533]
Jun 21 17:43:06 fedoraserver zmdc[3533]: INF ['zmaudit.pl -c' started at 11/06/21 17:43:06]
Jun 21 17:43:06 fedoraserver zmdc[3499]: INF ['zmwatch.pl' starting at 11/06/21 17:43:06, pid = 3538]
Jun 21 17:43:06 fedoraserver zmdc[3538]: INF ['zmwatch.pl' started at 11/06/21 17:43:06]
Jun 21 17:43:06 fedoraserver zmdc[3499]: INF ['zmupdate.pl -c' starting at 11/06/21 17:43:06, pid = 3543]
Jun 21 17:43:06 fedoraserver zmwatch[3538]: INF [Watchdog starting]
Jun 21 17:43:06 fedoraserver zmwatch[3538]: INF [Watchdog pausing for 30 seconds]
Jun 21 17:43:06 fedoraserver zmdc[3543]: INF ['zmupdate.pl -c' started at 11/06/21 17:43:06]
Jun 21 17:43:06 fedoraserver zmupdate[3543]: INF [Checking for updates]
Jun 21 17:43:07 fedoraserver zmfilter[3528]: INF [Scanning for events]
Jun 21 17:43:11 fedoraserver zmpkg[3548]: INF [Command: status]
Jun 21 17:43:14 fedoraserver zmupdate[3543]: INF [Got version: '1.24.4']
Jun 21 17:43:25 fedoraserver zms[3566]: INF [Debug Level = 0, Debug Log = <none>]
Jun 21 17:43:25 fedoraserver zms[3566]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.03566]
Jun 21 17:43:25 fedoraserver zms[3566]: INF [Authenticated user 'admin']
Jun 21 17:43:27 fedoraserver zms[3566]: INF [Got signal 15 (Terminated), exiting]
Jun 21 17:43:36 fedoraserver zmdc[3499]: ERR ['zmwatch.pl ' exited abnormally, exit status 9]
Jun 21 17:43:36 fedoraserver zmdc[3499]: INF [Starting pending process, zmwatch.pl]
Jun 21 17:43:36 fedoraserver zmdc[3499]: INF ['zmwatch.pl' starting at 11/06/21 17:43:36, pid = 3581]
Jun 21 17:43:36 fedoraserver zmdc[3581]: INF ['zmwatch.pl' started at 11/06/21 17:43:36]
Jun 21 17:43:36 fedoraserver zmwatch[3581]: INF [Watchdog starting]
Jun 21 17:43:36 fedoraserver zmwatch[3581]: INF [Watchdog pausing for 30 seconds]
Thanks so much for everyone's help! Does this mean I will have to manually start it though each reboot? Thanks again.
