Hi there
I'm running V1.24.4 on a newly installed Ubuntu 11.04 32bit
Under Options, I was looking at the various setting, and under Skins, I was able to select XML, and what a bummer, now I can't read the zm webpage!
Is there any way to revert back to classic HTML??
I did try to use phpmyadmin to see if the option was in there, but no
Any help is appreciated!
BR
Lars Bækmark
How To reset back to classic if I accidentally selected XML
Re: How To reset back to classic if I accidentally selected
http://your_ip/zm/index.php?skin=default
Info on skins is in the wiki
Thanx!!!!
It worked!
Lars
It worked!
Lars
Yes Thanks, I was "trying new settings out too.
I used
to get back to normal on zm 1.24.3
tom
I used
http://ipAddr/zm/index.php?skin=classic
tom
Don't Let Software Push You Around... Push Back
