Page 1 of 1
Debian 1.24.4 I need some help
Posted: Mon Jun 06, 2011 6:01 pm
by rangerbob
2.6.26-2-686
squeeze repositories
Note the warnings in the configure. I am unsure what to do. I loaded all the packages I could am I missing something? should I be compiling the ffmpeg to get it to work? what version do you recommend?
apt-get install apache2 mysql-client mysql-server php5 php5-mysql netpbm libpcre3 zlib1g libstdc++6 libwww-perl libphp-serialization-perl libmime-perl libmime-lite-perl libjpeg62 libgnutls26 libc6 libgcc1 libdevice-serialport-perl libdate-manip-perl libavutil49 libavformat52 libavcodec51 libarchive-tar-perl libarchive-zip-perl libapache2-mod-php5 ffmpeg
# ./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=asterisk --with-webgroup=asterisk --with-libarch=lib --with-ffmpeg=/usr/local --enable-mmap=yes --enable-debug=yes --disable-crashtrace ZM_SSL_LIB=opensslchecking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-mysql option.
    This tells configure where to find the MySql C library and headers if configure cannot
    locate them automatically.
    e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure: WARNING: You can call configure with the --with-extralibs option.
    Ordinarily you will need to use this option only when your copy of ffmpeg has been built
    with support for additional formats and you would use this option to detail which additional
    libraries ffmpeg was built with so that it is able to link successfully with ZoneMinder.
    You will need to wrap this option in quotes if it contains any spaces.
    e.g. --with-extralibs="-lmp3lame"
configure: WARNING: You can call configure with the --with-webhost option.
    This tells configure what the host name is for name based virtual hosting. This is only used to populate the sample web/zmHttpd.conf file.
    e.g. --with-webhost=zm.localdomain
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking whether ln -s works... yes
checking for ranlib... ranlib
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C++ preprocessor... g++ -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... no
checking for an ANSI C-conforming const... yes
checking for uid_t in sys/types.h... yes
checking for inline... inline
checking for mode_t... yes
checking for size_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking return type of signal handlers... void
checking for siginfo_t... yes
checking for struct sigcontext... yes
checking for struct sigcontext.eip... yes
checking for ucontext_t... yes
checking whether gcc needs -traditional... no
checking for stdlib.h... (cached) yes
checking for GNU libc compatible malloc... yes
checking for unistd.h... (cached) yes
checking for sys/param.h... yes
checking for getpagesize... yes
checking for working mmap... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking types of arguments for select... int,fd_set *,struct timeval *
checking whether lstat correctly handles trailing slash... yes
checking whether stat accepts an empty string... no
checking for strftime... yes
checking for working strtod... yes
checking for vprintf... yes
checking for _doprnt... no
checking for gethostbyname... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for memmove... yes
checking for memset... yes
checking for mkdir... yes
checking for munmap... yes
checking for putenv... yes
checking for select... yes
checking for socket... yes
checking for sqrt... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strcspn... yes
checking for strerror... yes
checking for strncasecmp... yes
checking for strrchr... yes
checking for strsignal... yes
checking for strspn... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoull... yes
checking for ffmpeg... yes
checking for ffmpeg... /usr/bin/ffmpeg
checking for pnmscale... no
checking for mysql_init in -lmysqlclient... yes
checking for jpeg_start_compress in -ljpeg... yes
checking for pthread_create in -lpthread... yes
checking for dlsym in -ldl... yes
checking for MD5 in -lcrypto... yes
checking for pcre_compile in -lpcre... yes
checking for x264_predict_16x16_init in -lx264... yes
checking for av_malloc in -lavutil... yes
checking for av_image_copy in -lavcore... yes
checking for avcodec_init in -lavcodec... yes
checking for av_new_stream in -lavformat... yes
checking for avdevice_register_all in -lavdevice... no
configure: WARNING: libavdevice.a may be required for MPEG streaming
checking for sws_scale in -lswscale... yes
checking for BZ2_bzCompress in -lbz2... yes
checking for compress in -lz... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for memory.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking for sys/param.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking linux/videodev.h usability... yes
checking linux/videodev.h presence... yes
checking for linux/videodev.h... yes
checking linux/videodev2.h usability... yes
checking linux/videodev2.h presence... yes
checking for linux/videodev2.h... yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... yes
configure: WARNING: libavutil/avutil.h: present but cannot be compiled
configure: WARNING: libavutil/avutil.h:     check for missing prerequisite headers?
configure: WARNING: libavutil/avutil.h: see the Autoconf documentation
configure: WARNING: libavutil/avutil.h:     section "Present But Cannot Be Compiled"
configure: WARNING: libavutil/avutil.h: proceeding with the compiler's result
configure: WARNING:     ## ------------------------------------- ##
configure: WARNING:     ## Report this to support@zoneminder.com ##
checking for libavutil/avutil.h... no
checking ffmpeg/avutil.h usability... no
checking ffmpeg/avutil.h presence... no
checking for ffmpeg/avutil.h... no
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... yes
configure: WARNING: libavcodec/avcodec.h: present but cannot be compiled
configure: WARNING: libavcodec/avcodec.h:     check for missing prerequisite headers?
configure: WARNING: libavcodec/avcodec.h: see the Autoconf documentation
configure: WARNING: libavcodec/avcodec.h:     section "Present But Cannot Be Compiled"
configure: WARNING: libavcodec/avcodec.h: proceeding with the compiler's result
checking for libavcodec/avcodec.h... no
checking ffmpeg/avcodec.h usability... no
checking ffmpeg/avcodec.h presence... no
checking for ffmpeg/avcodec.h... no
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... yes
configure: WARNING: libavformat/avformat.h: present but cannot be compiled
configure: WARNING: libavformat/avformat.h:     check for missing prerequisite headers?
configure: WARNING: libavformat/avformat.h: see the Autoconf documentation
configure: WARNING: libavformat/avformat.h:     section "Present But Cannot Be Compiled"
configure: WARNING: libavformat/avformat.h: proceeding with the compiler's result
checking for libavformat/avformat.h... no
checking ffmpeg/avformat.h usability... no
checking ffmpeg/avformat.h presence... no
checking for ffmpeg/avformat.h... no
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... yes
configure: WARNING: libswscale/swscale.h: present but cannot be compiled
configure: WARNING: libswscale/swscale.h:     check for missing prerequisite headers?
configure: WARNING: libswscale/swscale.h: see the Autoconf documentation
configure: WARNING: libswscale/swscale.h:     section "Present But Cannot Be Compiled"
configure: WARNING: libswscale/swscale.h: proceeding with the compiler's result
checking for libswscale/swscale.h... no
checking ffmpeg/swscale.h usability... no
checking ffmpeg/swscale.h presence... no
checking for ffmpeg/swscale.h... no
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
checking pcre.h usability... yes
checking pcre.h presence... yes
checking for pcre.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for fcntl.h... (cached) yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking whether round is declared... yes
checking whether MD5 is declared... yes
checking whether backtrace is declared... yes
checking for perl... perl
checking for perl version greater than or equal to 5.6.0... ok
checking for perl module Sys::Syslog... ok
checking for perl module DBI... ok
checking for perl module DBD::mysql... ok
checking for perl module Getopt::Long... ok
checking for perl module Time::HiRes... ok
checking for perl module Date::Manip... ok
checking for perl module LWP::UserAgent... ok
checking for perl module Sys::Mmap... ok
checking for perl module Module::Load... ok
checking for perl module Device::SerialPort... ok
checking for perl module Net::FTP... ok
checking for perl module Archive::Tar... ok
checking for perl module Archive::Zip... ok
checking for perl module Net::SMTP... ok
checking for perl module MIME::Lite... ok
checking for perl module MIME::Entity... ok
checking for perl module X10::ActiveHome... ok
configure: creating ./config.status
config.status: creating Makefile
config.status: creating zm.conf
config.status: creating zmconfgen.pl
config.status: creating db/Makefile
config.status: creating db/zm_create.sql
config.status: creating misc/Makefile
config.status: creating misc/apache.conf
config.status: creating misc/logrotate.conf
config.status: creating misc/syslog.conf
config.status: creating scripts/Makefile
config.status: creating scripts/zm
config.status: creating scripts/zmaudit.pl
config.status: creating scripts/zmcontrol.pl
config.status: creating scripts/zmdc.pl
config.status: creating scripts/zmfilter.pl
config.status: creating scripts/zmpkg.pl
config.status: creating scripts/zmtrack.pl
config.status: creating scripts/zmtrigger.pl
config.status: creating scripts/zmupdate.pl
config.status: creating scripts/zmvideo.pl
config.status: creating scripts/zmwatch.pl
config.status: creating scripts/zmx10.pl
config.status: creating scripts/zmdbbackup
config.status: creating scripts/zmdbrestore
config.status: creating scripts/zmeventdump
config.status: creating scripts/zmlogrotate.conf
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Base.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Config.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Memory.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/ConfigData.pm
config.status: creating src/Makefile
config.status: creating src/zm_config.h
config.status: creating web/Makefile
config.status: creating web/ajax/Makefile
config.status: creating web/css/Makefile
config.status: creating web/graphics/Makefile
config.status: creating web/includes/Makefile
config.status: creating web/includes/config.php
config.status: creating web/js/Makefile
config.status: creating web/lang/Makefile
config.status: creating web/skins/Makefile
config.status: creating web/skins/classic/Makefile
config.status: creating web/skins/classic/ajax/Makefile
config.status: creating web/skins/classic/css/Makefile
config.status: creating web/skins/classic/graphics/Makefile
config.status: creating web/skins/classic/includes/Makefile
config.status: creating web/skins/classic/js/Makefile
config.status: creating web/skins/classic/lang/Makefile
config.status: creating web/skins/classic/views/Makefile
config.status: creating web/skins/classic/views/css/Makefile
config.status: creating web/skins/classic/views/js/Makefile
config.status: creating web/skins/mobile/Makefile
config.status: creating web/skins/mobile/ajax/Makefile
config.status: creating web/skins/mobile/css/Makefile
config.status: creating web/skins/mobile/graphics/Makefile
config.status: creating web/skins/mobile/includes/Makefile
config.status: creating web/skins/mobile/lang/Makefile
config.status: creating web/skins/mobile/views/Makefile
config.status: creating web/skins/mobile/views/css/Makefile
config.status: creating web/tools/Makefile
config.status: creating web/tools/mootools/Makefile
config.status: creating web/views/Makefile
config.status: creating web/skins/xml/Makefile
config.status: creating web/skins/xml/views/Makefile
config.status: creating web/skins/xml/includes/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing src/zm_config_defines.h commands
Generating 'src/zm_config_defines.h'
Updating 'db/zm_create.sql'
config.status: executing scripts/ZoneMinder/Makefile commands
perl Makefile.PL
Writing Makefile for ZoneMinder
/usr/src/ZoneMinder-1.24.4# make
make  all-recursive
make[1]: Entering directory `/usr/src/ZoneMinder-1.24.4'
Making all in src
make[2]: Entering directory `/usr/src/ZoneMinder-1.24.4/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/local/include -Wall -Wno-sign-compare -fno-inline -I/usr/local/include   -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_mpeg.h:23,
                 from zm_stream.h:27,
                 from zm_event.h:39,
                 from zm_zone.h:27,
                 from zm_monitor.h:26,
                 from zmc.cpp:28:
zm_ffmpeg.h:37:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:44:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:51:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:59:2: error: #error "No location for swscale.h found"
In file included from zm_stream.h:27,
                 from zm_event.h:39,
                 from zm_zone.h:27,
                 from zmc.cpp:28:
zm_mpeg.h:43: error: use of enum âPixelFormatâ without previous declaration
zm_mpeg.h:44: error: ISO C++ forbids declaration of âAVOutputFormatâ with no type
zm_mpeg.h:44: error: expected â;â before â*â token
zm_mpeg.h:45: error: ISO C++ forbids declaration of âAVFormatContextâ with no type
zm_mpeg.h:45: error: expected â;â before â*â token
zm_mpeg.h:46: error: ISO C++ forbids declaration of âAVStreamâ with no type
zm_mpeg.h:46: error: expected â;â before â*â token
zm_mpeg.h:47: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_mpeg.h:47: error: expected â;â before â*â token
zm_mpeg.h:48: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_mpeg.h:48: error: expected â;â before â*â token
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/usr/src/ZoneMinder-1.24.4/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/ZoneMinder-1.24.4'
make: *** [all] Error 2
Re: Debian 1.24.4 I need some help
Posted: Thu Jun 09, 2011 3:21 pm
by andrelg
Try to update your kernel to 2.6.30 or higher, so ZM can find your boards (if you'll use boards) easily.
Also, did you tried to install zoneminder from apt ?
Posted: Thu Jun 09, 2011 5:58 pm
by rangerbob
I am able to compile now. without upgrading the kernel.
No I am using foscam cheap ip cams
I been playing with this script, http://www.zoneminder.com/forums/viewto ... 21&t=17665 see my responce there..
at this point it looked like a perl version (I am running 5.10.1) problem but I have since put a symbolic link in and it still gives the same error
ERROR 1007 (HY000) at line 1: Can't create database 'zm'; database exists
Can't locate ZoneMinder.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.10.1 /usr/local/share/perl/5.10.1 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl /usr/local/lib/perl/5.10.0 /usr/local/share/perl/5.10.0) at /usr/local/bin/zmpkg.pl line 46.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 46.
