null events...
tibetfreedom
null events...
Post by tibetfreedom »
I'm getting a few of these in the events window…
Odd any idea's… ?
7706 New Event 2011-06-07 18:13:33 0.00 null/null 0/0
PacoLM
Re: null events...
Post by PacoLM »
Check that the path to store the events are properly set. Are you storing the data locally or in an external location?. Take a look to the /var/log/syslog file to see the error you're getting when an event is raised.
Hope it helps,
PacoLM
tibetfreedom
Re: null events...
PacoLM wrote:Check that the path to store the events are properly set. Are you storing the data locally or in an external location?. Take a look to the /var/log/syslog file to see the error you're getting when an event is raised.
Hope it helps,
PacoLM
Stored locally.
cordel
Re: null events...
Post by cordel »
Run a check on your database as described in the wiki. I'm guessing that you have a couple tables that didn't close properly.
tibetfreedom
Re: null events...
cordel wrote:Run a check on your database as described in the wiki. I'm guessing that you have a couple tables that didn't close properly.
Hi thanks,
where does it say that in the wiki… ?
thanks…
andrelg
Re: null events...
Post by andrelg »
tibetfreedom
Re: null events...
Err where…………….. I can't find the actual reference in the Wiki ….
Obviously I can find the Wiki…
Thanks.
zoneminder
Site Admin
Re: null events...
Post by zoneminder »
What version of ZM? Are the zma processes crashing?
Phil
tibetfreedom
Re: null events...
zoneminder wrote:What version of ZM? Are the zma processes crashing?
Oh I don't know,
just installed phpmyadmin
apt-get install phpmyadmin
and repaired the events table…
but not sure about the zma processes how do I check for that ?
