Page 1 of 1
Compilation errors with 03 optimization
Posted: Tue Jun 07, 2011 11:34 pm
by erict35
Hi
I'm using a Ubuntu 11.04 Desktop 64 bits.
As recommended in the Wiki documentation, I tried using -O3 in order to optimize code
The parameters are :
export CFLAGS="-march=native -O3 -pipe"
export CXXFLAGS="${CFLAGS}"
export CPPFLAGS="${CFLAGS}"
When compiling graphic components like x264 and ffmpeg, I got no problems with these options
When compiling ZoneMinder 1.24.4 I got one :
zm_rtp_source.o: In function `RtpSource::handlePacket(unsigned char const*, unsigned long)':
zm_rtp_source.cpp:(.text+0xf15): undefined reference to `ThreadData<bool>::updateValueSignal(bool)'
zm_rtp_source.cpp:(.text+0xf32): undefined reference to `ThreadData<bool>::getUpdatedValue(int) const'
zm_rtp_source.cpp:(.text+0xf43): undefined reference to `ThreadData<bool>::getUpdatedValue(int) const'
zm_rtp_source.cpp:(.text+0xf54): undefined reference to `ThreadData<bool>::getUpdatedValue(int) const'
zm_rtp_source.o: In function `RtpSource::getFrame(Buffer&)':
zm_rtp_source.cpp:(.text+0x10c2): undefined reference to `ThreadData<bool>::getUpdatedValue(int) const'
zm_rtp_source.cpp:(.text+0x10d3): undefined reference to `ThreadData<bool>::getUpdatedValue(int) const'
zm_rtp_source.o:zm_rtp_source.cpp:(.text+0x10e6): more undefined references to `ThreadData<bool>::getUpdatedValue(int) const' follow
zm_rtp_source.cpp:(.text+0x113f): undefined reference to `ThreadData<bool>::updateValueSignal(bool)'
zm_timer.o: In function `Timer::TimerThread::run()':
zm_timer.cpp:(.text+0x4b): undefined reference to `ThreadData<bool>::setValue(bool)'
zm_timer.cpp:(.text+0x61): undefined reference to `ThreadData<bool>::getUpdatedValue(int) const'
zm_timer.o: In function `Timer::TimerThread::cancel()':
zm_timer.cpp:(.text+0x34d): undefined reference to `ThreadData<bool>::updateValueSignal(bool)'
zm_timer.o: In function `Timer::TimerThread::reset()':
zm_timer.cpp:(.text+0x4c3): undefined reference to `ThreadData<bool>::updateValueSignal(bool)'
collect2: ld returned 1 exit status
make[2]: *** [zmc] Erreur 1
If I change the compiler parameters as these :
export CFLAGS="-march=native -O2 -pipe"
I can compile ZoneMinder and launch it without problem
Any help appreciated
Best Regards
Eric
