I had a new PC that I installed Ubuntu Maverick via Windows. I installed zm 1.2.3 or 4 (can't recall), and it worked fine. I decided to do a new install of Maverick outside of Windows and then add zm 1.24. I can't get any video to work, no matter what settings I use.
error logs show the following on startup:
Jun 9 14:55:41 mint-1 zmdc[4327]: INF [Starting pending process, zmc -d /dev/video0]
Jun 9 14:55:41 mint-1 zmdc[4327]: INF ['zmc -d /dev/video0' starting at 11/06/09 14:55:41, pid = 4383]
Jun 9 14:55:41 mint-1 zmdc[4383]: INF ['zmc -d /dev/video0' started at 11/06/09 14:55:41]
Jun 9 14:55:41 mint-1 zmc_dvideo0[4383]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 14:55:41 mint-1 zmc_dvideo0[4383]: INF [Starting Capture]
Jun 9 14:55:41 mint-1 zmc_dvideo0[4383]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Jun 9 14:57:01 mint-1 zmdc[4327]: INF [Starting pending process, zmc -d /dev/video0]
Jun 9 14:57:01 mint-1 zmdc[4327]: INF ['zmc -d /dev/video0' starting at 11/06/09 14:57:01, pid = 4385]
Jun 9 14:57:01 mint-1 zmdc[4385]: INF ['zmc -d /dev/video0' started at 11/06/09 14:57:01]
Jun 9 14:57:01 mint-1 zmc_dvideo0[4385]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 14:57:01 mint-1 zmc_dvideo0[4385]: INF [Starting Capture]
Jun 9 14:57:01 mint-1 zmc_dvideo0[4385]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Jun 9 14:59:41 mint-1 zmdc[4327]: INF [Starting pending process, zmc -d /dev/video0]
Jun 9 14:59:41 mint-1 zmdc[4327]: INF ['zmc -d /dev/video0' starting at 11/06/09 14:59:41, pid = 4415]
Jun 9 14:59:41 mint-1 zmdc[4415]: INF ['zmc -d /dev/video0' started at 11/06/09 14:59:41]
Jun 9 14:59:41 mint-1 zmc_dvideo0[4415]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 14:59:41 mint-1 zmc_dvideo0[4415]: INF [Starting Capture]
Jun 9 14:59:41 mint-1 zmc_dvideo0[4415]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
lshw shows the following:
-multimedia:0
description: Multimedia video controller
product: Bt878 Video Capture
vendor: Brooktree Corporation
physical id: 5
bus info: pci@0000:02:05.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: vpd pm bus_master cap_list
configuration: driver=bttv latency=64 maxlatency=40 mingnt=16
resources: irq:20 memory:fdfff000-fdffffff
lspci info:
02:05.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:05.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
lsmod info:
v4l2_common 17329 1 bttv
snd 49006 13 snd_hda_codec_via,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
ir_rc5_decoder 1950 0
sparse_keymap 3145 0
videodev 43098 2 bttv,v4l2_common
v4l1_compat 13359 1 videodev
videobuf_dma_sg 9870 1 bttv
ir_nec_decoder 2014 0
asus_atk0110 11423 0
videobuf_core 16907 2 bttv,videobuf_dma_sg
btcx_risc 3700 1 bttv
ir_common 5167 1 bttv
