AxisMotionDetection update
ocgltd
Post by ocgltd »
I'm looking at the AxisMotionDetection section of the wiki and wonder if:
1. Does this still apply to ZM 1.24.x ?
2. Did you try inserting the plus sign into the message at the camera using hex encoding? eg: "1|on%2B5|5|cause|text|showtext"
3. Why are you using a regex to remove quotes from the received message? Is this necessary?
4. In the zmtrigger.pl file, why have you commented our some of the push/pulls?
Thanks!
ocgltd
Re: AxisMotionDetection update
Post by ocgltd »
I figured out my own answers - yes all still required.
Has anyone tried use a start command for motion, and stop command on no motion? (Otherwise ZM just records whatever time is sent in the message)
