I'm trying to figure out what dictates event scores. I noticed some events had a higher score. When I checked, there seemed to be more movement in those events. On a hunch, I went out and walked in front of the camera several times. Sure enough, the score for that particular event was 0/0.
So what's different from what I did versus the other events? What is it that makes ZoneMinder think, oh this deserves a 10/12, or whatever. Any idea?
What dictates event scores?
Re: What dictates event scores?
The motion detection algorithm, based on the difference between the captured image and the reference image.
mastertheknife.
mastertheknife.
Kfir Itzhak.
So if I'm running on "record" mode, I won't see scores? Only if I'm on modetect or morecord?
Also, I can't seem to find the setting where once motion record is in session, how long that event records for... any idea?
Motion duration plus the pre and post buffer lengths; makes it your choice on how long
