Page 1 of 1
64 char limit in Remote Host Path on Ubuntu 11.04 desktop?
Posted: Tue Jun 14, 2011 5:25 pm
by eufreka
I just installed Ubuntu 11.04 Desktop and after a lot of hassles, ended up with a working Zoneminder 1.24.2 install theoretically based on the Ubuntu package (natty) version (Forum won't allow me to link to it.)
I am only using Remote IP Cameras.
However, I seem to have a hard 64 character limit in the "Remote Host Path" under the Source Tab of the Monitors.
Consequently, it only accepts a short path:
TOO LONG xxxx://userx:passwd@xx.xx.xx.xxx/nphMotionJpeg?Resolution=320x240?Quality=Standard (82 char)
TOO LONG xxxx://xx.xx.xx.xxx/nphMotionJpeg?Resolution=320x240?Quality=Standard (69 char)
WORKS xxxx://xx.xx.xx.xxx/nphMotionJpeg?Resolution=320x240 (52 char)
If I enter a too long path and save it, it is truncated at 64 characters. As a result, it is an invalid path and the camera doesn't connect. However, by trial and error, I discovered that if I could construct a path of 64 or less, it works fine.
The cameras have restrictions on username/password length, so I am stuck without authentication on the cams for now.
Is this a known (intentional) limitation? Could I have messed up the install? Is there a simple fix?
Re: 64 char limit in Remote Host Path on Ubuntu 11.04 deskto
Posted: Wed Jun 15, 2011 9:28 pm
by PacoLM
You could try to modify the lenght of the field in the database, using phpmyadmin, for instance, it's in the table monitors. I do not know if changing this could mess up your previous settings, let's wait for the answer of an expert!.
PacoLM
Posted: Thu Jun 16, 2011 12:46 am
by mastertheknife
You can safely increase this field to 256 bytes or more.
mastertheknife.
Posted: Thu Jun 16, 2011 2:17 am
by eufreka
Well, I just installed ZMLarch to see if it has the same limitation; and it does. This surprises me for 2 reasons:
First, my old install (several versions back) blew up, which led me to examine the newer versions; it did not have this same limitation.
So this appears to be a deliberate change?
Second, the basic remote path for my Pana BL-c10a cams is too long to conform to that limit, even without using on-camera authentication (which I did previously).
So it is exceedingly odd that no one has mentioned this before as far as I can tell.
Posted: Thu Jun 16, 2011 3:30 am
by bb99
It has been mentioned before but isn't showing up for me in forum searches; can't say why but I'm probably not using the correct search terms. PacoLM's fix is the answer as alluded to by Mastertheknife.
Posted: Fri Jun 17, 2011 7:54 am
by mastertheknife
eufreka wrote:Well, I just installed ZMLarch to see if it has the same limitation; and it does. This surprises me for 2 reasons:
The Path field was increased from 64 bytes to 255 bytes in ZoneMinder 1.24.3 and newer, but this only applies to newly created databases (created with the updated zm_create.sql file).
mastertheknife.
Posted: Sat Jun 18, 2011 4:42 am
by eufreka
mastertheknife wrote:You can safely increase this field to 256 bytes or more.
mastertheknife.
So I did expand the field and it holds the longer path...but I still cannot get an image in the Monitor as long as I have camera authentication incorporated into the Path. Strange.
(I did test the path directly in the browser and it works fine.)
((And it worked in my old installation!))
Posted: Sat Jun 18, 2011 5:01 am
by bb99
Pulled this from another post:
http://www.zoneminder.com/forums/viewto ... nic+BL+c10
Remote Host Name - UsersName:Password@192.168.1.21
Remote Host Port - 80
Remote Host Path - /snapshotjpegResolution=320x240&Quality=Clarity
Might help?
