Filters question
Tiggy
Filters question
Post by Tiggy »
I looked everywhere but can't find any info on this.
I had a filter running in background removing all events older than 7 days on an older version of zm and forget to back it up ... After new install I lost it off course :|
Can't remember how I managed to actually make it work ... can anyone help me?
Thx
bb99
Re: Filters question
Post by bb99 »
I believe the value your looking for is "-1 week" or "-7 days" as a replacement for "now" in the new filter window. Some things not to forget: make sure to enter a number in the "limit to the first ____ results only"; in your case a high value will work. And when you save and name the filter, be sure to check the run in background box.
Tiggy
Post by Tiggy »
Thx, I ll try this out tonight :)
