Page 1 of 1
pb with a modified perl script to trigger an alarm
Posted: Fri Jun 17, 2011 10:13 am
by gilles
Hi all,
Sorry for the title of that post but I don't find anything else.
I search but don' find in the web and forum.
I want to use that script from the FAQ:
http://www.zoneminder.com/wiki/index.ph ... n_alarm.3F
I want to detect an alarm and print to screen (for the moment): I want to print the name of the monitor, the notes (Motion: Blah blha), and the last event id number.
for that I modify my sql selection and add the notes like that:
my $sql = "select M.*, E.Id as LastEventId, Notes from Monitors as M left join Events as E on M.Id = E.MonitorId ORDER BY E.Id DESC LIMIT 0,1";
Before using the While (1), I print all my informations and that's good for the lasevnetId (I verify In mysql).
So my problem is to detect an alarm and print the last alarm with what I want upper.
I understand approximatively all the code except: !zmMemVerify( $monitor ) and the expression zmHasAlarmed( $monitor, $monitor->{LastEventId}
Could someone help me please.
I Think this isn't too hard but I'm new to perl and don't know where to find that two expression.
Gilles.
Re: pb with a modified perl script to trigger an alarm
Posted: Sun Jun 19, 2011 8:07 am
by gilles
Nobody can help me.
Sure I'm not alone, that I want to get my alarm by script.
So please help.
Thank you.
Gilles.
Posted: Wed Jun 29, 2011 7:01 am
by gilles
So nobody.
I can do it myself if only I know how "zmMemVerify( $monitor )" and zmHasAlarmed work.
thank you.
Posted: Wed Jun 29, 2011 7:31 am
by zoneminder
I'm not quite sure what you are asking. You have the script from the FAQ, you should leave all that code as it is (though you may wish to rerun the monitor selection code periodically). Do not modify the sql that is in the example as that is not to select events but only to select monitors.
Basically all you need to do is add you code into this section
# Do your stuff here
. In there you can do what you want, knowing that you will only get there is there is an alarm. For instance that section would be where you would select the event details from the database and output them or do something else.
Posted: Wed Jun 29, 2011 8:02 am
by gilles
ok If I understand, I'm wrong.
I have to use your code and then in the personal part I do my database selection and use what I want in the "do your stuff zone".
Right ?
If it is that, thank you, you open my eyes.
Gilles.
Posted: Wed Jun 29, 2011 11:42 am
by gilles
I think my explanations aren't good.
I add in your script that:
print( "Monitor ".$monitor->{Name}." has alarmed ".$monitor->{Notes}."\n" );
because I want to know what is the zone who has got an alarm. I've got what I want except that this the Notes at a certain time but not the last time.
If there is an alarm it's ok, but if I got a new alarm it writes the old one. You understand.
I just want to know the "Name" and the "Notes" of the "Motion" in real time if there is alarm.
Could you help me please.
PS:
If I use your script I've got that error: Use of uninitialized value $last_event_id in numeric ne (!=) at /usr/share/perl5/ZoneMinder/Memory.pm line 497
If I do a modification on the mysql selection like that, it works: my $sql = "select M.*, E.Id as LastEventId, Notes from Monitors as M left join Events as E on M.Id = E.MonitorId ORDER BY E.Id DESC LIMIT 0,1";
Gilles.
Posted: Wed Jun 29, 2011 12:57 pm
by zoneminder
The monitor SQL is excuted only once, at the beginning so the results you get from that will never change. The Notes field in that context does not make any sense.
You need to be querying the Events table to get Notes out, and do that in the block I identified each time there is a new alarm.
Something like
my $eventSql = "select * from Events where Id = ?";
my $eventSth = $dbh->prepare_cached( $eventSql ) or die( "Can't prepare '$eventSql': ".$dbh->errstr() );
my $eventRes = $eventSth->execute( $last_event_id ) or die( "Can't execute '$sql': ".$eventSth->errstr() );
my $event = $eventSth->fetchrow_hashref();
// Do something with $event
$eventSth->finish();
The first two lines can go anywhere in the file (they only need to be executed once) but the others should go in the loop.
Posted: Wed Jun 29, 2011 2:17 pm
by gilles
Thank you a lot.
I will try and let you an info, if I'm ok or not.
If it works my zoneminder will trigger in real time some zones with boolean decision to avoid false detection in first plan of my monitor.
I know my explanation is too long but if it's work I will post what I do for others.
Gilles.
Posted: Thu Jun 30, 2011 12:22 pm
by gilles
Hi Phil,
Really sorry, but always got a problem.
When I add your code and mine like that:
my $eventRes = $eventSth->execute($last_event_id) or die( "Can't execute '$sql': ".$eventSth->errstr() );
my @eventRes;
while ( my $eventRes = $eventSth->fetchrow_hashref() )
push( @eventRes, $eventRes);
print("event".$eventRes->{MonitorId}."\n");
and When an alarm happen, I've got that error:
DBD::mysql::st execute failed: called with 1 bind variables when 0 are needed at ./zm_alarm_def3.pl line 36.
Can't execute 'select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' group by (M.Id)': called with 1 bind variables when 0 are needed at ./zm_alarm_def3.pl line 36.
The line 36 is: my $eventRes = $eventSth->execute($last_event_id) or die( "Can't execute '$sql': ".$eventSth->errstr() );
Could you help me a last time, please ?
gilles.
Posted: Thu Jun 30, 2011 7:13 pm
by zoneminder
Please post your whole script.
By the way this line
Should be
my $eventRes = $eventSth->execute($last_event_id) or die( "Can't execute '$eventSql': ".$eventSth->errstr() );
but that only means that the correct SQL stateent will be reported in the error and won't make any difference other than that.
Posted: Fri Jul 01, 2011 11:28 am
by gilles
Hi Phil,
Here is the code:
#!/usr/bin/perl -w
use strict;
use ZoneMinder;
$| = 1;
my $sql = "select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' group by (M.Id)";
my $eventSql = "select max(Notes) from Events";
my @monitors;
push( @monitors, $monitor );
while( 1 )
next if ( !zmMemVerify( $monitor ) );
my @eventRes;
sleep (1);
sleep( 1 );
In order to test my script, I put a basic selection like : "select max(Notes) from Events", if it works I will put a better selection.
Really sorry to disturb you but it's impotant for me that this script works.
Thank you for your help.
Gilles.
Posted: Fri Jul 01, 2011 11:45 am
by zoneminder
That is your problem,
does not make any sense and is also what is causing the error.
You need to use a query like I suggested in my example,
If you only want the Notes field then you can change it to
my $eventSql = "select Notes from Events where Id = ?";
It is probably worth your while spending some time reading up on SQL and perl DBI if you want to do anything more sophisticated than that.
