forum and it seems that it's not a real popular problem but it follows me through total fresh installs including a new
database. I just removed all my config files and ZoneMinder and installed a fresh copy of 1.24.4.. new database... new
config files .. totally new install and I'm still having this issue.
This issue shows itself when trying to view a captured event. Most of the times I can view the events .. sometimes while
using gapless event they will pause but start playing again .. sometimes I get a black screen saying "Time to next
event = x seconds" x usually is one or two seconds. Whether it pauses or I get the black screen... when I check my error
log I see a bunch of errors like this:
[Thu Jun 23 10:33:06 2011] [error] [client 192.168.xxx.xxx] socket_sendto( /tmp/zm/zms-284884s.sock ) failed: No such
file or directory, referer: website/zm/index.php?view=watch&mid=2
[Thu Jun 23 10:33:06 2011] [error] [client 192.168.xxx.xxx] array (\n 0 => \n array (\n 'file' => '/path/zm/ajax/stream.php',\n
'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zm/zms-284884s.sock )
failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/path/zm/index.php',\n 'line' => 119,\n 'args' =>
\n array (\n 0 => '/path/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: website/zm/index.php?view=watch&mid=2
[Thu Jun 23 10:37:17 2011] [error] [client 192.168.xxx.xxx] socket_sendto( /tmp/zm/zms-244824s.sock ) failed: No such file or
directory, referer: website/zm/index.php?view=event&eid=27&filter[terms][0][attr]=Id&&filter[terms][0][op]=%3D%5B%5D&&filter[terms[0[val]=27%2C28%2C29%2C31%2C32%2C33%2C34%2C35%2C36%2C37%2C38%2C39%2C40%2C4
2C42%2C43%2C44%2C45%2C46%2C47%2C48%2C49%2C50%2C51%2C52%2C53%2C54%2C55%2C56%2C57%2C58%2C59%
2C60%2C61%2C62%2C63%2C64%2C65%2C66%2C67%2C68%2C69%2C70%2C71%2C72%2C73%2C74%2C75%2C76%2C77%2
C78%2C79%2C80%2C81%2C82%2C83%2C84%2C85%2C86%2C87%2C88%2C89%2C90%2C91%2C92&sort_field=StartTime&
sort_asc=1&page=1&play=1
[Thu Jun 23 10:37:17 2011] [error] [client 192.168.xxx.xxx] array (\n 0 => \n array (\n 'file' => '/path/zm/ajax/stream.php',\n
'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zm/zms-244824s.sock ) fail
ed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/path/zm/index.php',\n 'line' => 119,\n 'args' => \n
array (\n 0 => '/path/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: website/zm/index.php?view=event&eid=27&filter[terms]
[0][attr]=Id&&filter[terms][0][op]=%3D%5B%5D&&filter[terms][0][val]=27%2C
28%2C29%2C31%2C32%2C33%2C34%2C35%2C36%2C37%2C38%2C39%2C40%2C41%2C42%2C43%2C44%2C45%2C46%2C
47%2C48%2C49%2C50%2C51%2C52%2C53%2C54%2C55%2C56%2C57%2C58%2C59%2C60%2C61%2C62%2C63%2C64%2C
65%2C66%2C67%2C68%2C69%2C70%2C71%2C72%2C73%2C74%2C75%2C76%2C77%2C78%2C79%2C80%2C81%2C82%2C
83%2C84%2C85%2C86%2C87%2C88%2C89%2C90%2C91%2C92&sort_field=StartTime&sort_asc=1&page=1&play=1
[Thu Jun 23 10:44:06 2011] [error] [client 192.168.xxx.xxx] socket_sendto( /tmp/zm/zms-380199s.sock ) failed: No such file or
2C39%2C40%2C41%2C42%2C43%2C44%2C45%2C46%2C47%2C48%2C49%2C50%2C51%2C52%2C53%2C54%2C55%2C56
%2C57%2C58%2C59%2C60%2C61%2C62%2C63%2C64%2C65%2C66%2C67%2C68%2C69%2C70%2C71%2C72%2C73%2C7
4%2C75%2C76%2C77%2C78%2C79%2C80%2C81%2C82%2C83%2C84%2C85%2C86%2C87%2C88%2C89%2C90%2C91%2C9
[Thu Jun 23 10:44:06 2011] [error] [client 192.168.xxx.xxx] array (\n 0 => \n array (\n 'file' => '/path/zm/ajax/stream.php
',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zm/zms-380199s.so
ck ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/path/zm/index.php',\n 'line' => 119,\n 'arg
s' => \n array (\n 0 => '/path/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: website/zm
/index.php?view=event&eid=27&filter[terms][0][attr]=Id&&filter[terms][0][op]=%3D%5B%5D&&filter[terms]
[0][val]=27%2C28%2C29%2C31%2C32%2C33%2C34%2C35%2C36%2C37%2C38%2C39%2C40%2C41%2C42%2C43%2C44%
2C45%2C46%2C47%2C48%2C49%2C50%2C51%2C52%2C53%2C54%2C55%2C56%2C57%2C58%2C59%2C60%2C61%2C62%
2C63%2C64%2C65%2C66%2C67%2C68%2C69%2C70%2C71%2C72%2C73%2C74%2C75%2C76%2C77%2C78%2C79%2C80%
2C81%2C82%2C83%2C84%2C85%2C86%2C87%2C88%2C89%2C90%2C91%2C92&sort_field=StartTime&sort_asc=1&page=1&
play=1
information just let me know.
Thanks in advance,
John Orion
