Hey guys,
A small question (I hope). Where can I find the Event index number, so I can reset it? I have done a wiki and forum search but I guess the terms "event", "index" & "number" are a bit too generic.
Regards,
M.
Edit: I expected that it would be somewhere in the db, but I can't find it.
[SOLVED] Reset Event index?
Re: Reset Event index?
Its an auto-incrementing field in the Events table as far as i remember. You can use phpmyadmin to change it.
mastertheknife
mastertheknife
Kfir Itzhak.
Lol. Yeah, sorry... Auto_Increment finally seeped into my dim consciousness and I fixed it up with:
Thanks for your help.
M.
ALTER TABLE Events AUTO_INCREMENT=1
M.
