[SOLVED] Monitor window don't show events and fps
ZoneMinder 1.24.4 don't update the events in the monitor window. Also the fps field is blank. This was also an issue in version 1.24.3 but that could be fix by patching zmconfgen.pl.in. The zm init script don't work by default in fedora. Using dos2unix on the file 'zm' fix this. Has somebody else run into all of this, and what to do to make the events show up in de monitor window? How to fix the fps field?
Re: Monitor window don't show events and fps
In ZM settings, verify cambozola reload value is set to something (e.g. 0) and is not blank, this is a common problem.
Also, make sure you are using PHP 5.3.0 or newer with sockets enabled.
mastertheknife
mastertheknife
Kfir Itzhak.
mastertheknife wrote:In ZM settings, verify cambozola reload value is set to something (e.g. 0) and is not blank, this is a common problem.
mastertheknife
Thanks! After upgrading mysql and php everything works okee.
