Planet IP camera ICA-HM126 or ICA-HM131 M-JPEG stream setup?
ipcam
Post by ipcam »
Does anyone have any advice on setting the M-JPEG streams in Zone Minder?
The stream rtsp://<ipaddress>/jpeg (on port554) displays in VLC network stream view.
<ipaddress>:8008 displays the stream in firefox (MJPEG over HTTP).
rtsp://<ipaddress>/jpeg using ffmpeg stream does not display in Zone Minder (on Ububtu 10.04, Package version 1.24.snv20110306-1).
Resolution: 1920 x 1080
Has anyone got these working?
Any sugestions, thank you?
Flasheart
Re: Planet IP camera ICA-HM126 or ICA-HM131 M-JPEG stream se
Post by Flasheart »
Use the http one. (unusual to see rtsp on an mjpeg, don't know if zm will read rtsp on a remote filetype)
And with that resolution, you're going to need to amend the shared memory settings upwards a fair chunk (see faq). Not sure of an exact number, but possible 3x or even 4x what's in the faq.
What specific problems are you seeing?
MarvinLamont
Post by MarvinLamont »
The PLANET Surveillance system can create a suitable home care system with the latest IP surveillance technologies. It can easily do by users to set up a functional surveillance system.
