Page 1 of 1
admin account deleted
Posted: Sat Jul 09, 2011 10:03 am
by cisco
I have deleted admin account from zoneminder and now I cannot log in.
How can this be fixed?
I have tryed to add new user to mysql database but it seems not working.
I am also new to sql and some help would be appreciated.
Re: admin account deleted
Posted: Sat Jul 09, 2011 10:09 am
by cisco
its ok now used this command to create admin user with pass: changepassword
Code:
INSERT INTO `Users` (`Id`, `Username`, `Password`, `Language`, `Enabled`, `Stream`, `Events`, `Control`, `Monitors`, `Devices`, `System`, `MaxBandwidth`, `MonitorIds`) VALUES
(1, 'admin', '*3B34B40DAE3DD1E15943B37622F688A6D7F8002D', 'en_gb', 1, 'View', 'Edit', 'Edit', 'Edit', 'Edit', 'Edit', '', '');
Posted: Fri Feb 17, 2017 2:31 am
by mysterylectricity
This worked for me as well. For those of you who are not familiar with using mysql, the following commands are prerequisite:
mysql -u root -p
Enter password:
If you have not set an explicit password for mysql, the system root password worked for me.
Then select the zm database:
use zm;
And then:
This will set the deafult login to admin and the default password to changepassword.
The changes take effect immediately. Change your password and add another privileged user in case you make thew same mistake again.
