changed path, cannot see events anymore (SOLVED)
Posted: Tue Jul 19, 2011 11:39 am
I'm running zm 1.24.2.
Ive changed the option DIR_EVENTS to store the images on an other partition and actually the images are created there, zm console is showing the correct events details but I can't replay/view them from the console.
Is there something more to do than changing DIR_EVENTS option?
Thank you
Thank you
