Page 1 of 1
Can't edit, delete or select monitor source
Posted: Thu Jul 21, 2011 1:55 pm
by naoliv
Hi!
I have installed Debian's zoneminder (version is 1.24.2) and while it seems to be working (I can access zoneminder through http: //127.0.0.1/zm/) I am seeing some problems:
Clicking in "Add New Monitor" I am able to use only the "General" tab. All other tabs are disabled (clicking on them and nothing happens). Tried on Chrome and Opera. Real problem in zoneminder or something related with javascript, supported browsers, etc?
Another thing: after creating a monitor (just to test, since I can't configure it because only "General" is available), I am also unable to edit nor delete it.
By clicking on "Mark" and selecting the monitor, both the Edit and Delete buttons are disabled.
Again, something wrong with zoneminder or something related with javascript/browsers?
Re: Can't edit, delete or select monitor source
Posted: Thu Jul 21, 2011 7:03 pm
by PacoLM
Read this posthttp://www.zoneminder.com/forums/viewto ... 138#p69138. Hope it helps.
PacoLM
Posted: Thu Jul 21, 2011 7:16 pm
by naoliv
Perfect! :D
A big thank you!
Posted: Fri Feb 01, 2013 10:17 pm
by sealevelpete
bump
Unfortunately, this did not work for me. :( Does anyone have any further guidance?
Thanks in advance!
sealevelPete
Installed on Mepis:
popeye@popeye:~$ uname -a
Linux popeye 2.6.36-1-mepis-smp #1 SMP Thu Mar 31 17:07:18 CDT 2011 i686 GNU/Linux
Installed from synaptic, install worked fine, however I had to move the zm folder to /var/www
Logs:
tail /var/tmp/*.log
==> /var/tmp/zmaudit.log <==
==> /var/tmp/zmdc.log <==
02/01/2013 17:13:40.136542 zmdc[3699].INF ['zmc -m 1' crashed, signal 6]
02/01/2013 17:13:41.039023 zmdc[3699].INF [Starting pending process, zmfilter.pl]
02/01/2013 17:13:41.040937 zmdc[3699].INF ['zmfilter.pl' starting at 13/02/01 17:13:41, pid = 3833]
02/01/2013 17:13:41.394194 zmdc[3699].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
02/01/2013 17:16:20.085588 zmdc[3699].INF [Starting pending process, zmc -m 1]
02/01/2013 17:16:20.087368 zmdc[3699].INF ['zmc -m 1' starting at 13/02/01 17:16:20, pid = 3862]
02/01/2013 17:16:20.139353 zmdc[3699].INF ['zmc -m 1' crashed, signal 6]
02/01/2013 17:16:21.042184 zmdc[3699].INF [Starting pending process, zmfilter.pl]
02/01/2013 17:16:21.044099 zmdc[3699].INF ['zmfilter.pl' starting at 13/02/01 17:16:21, pid = 3863]
02/01/2013 17:16:21.352893 zmdc[3699].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
==> /var/tmp/zmpkg.log <==
02/01/2013 17:11:01.674567 zmpkg[3686].INF [Command: start]
==> /var/tmp/zmwatch.log <==
02/01/2013 17:15:56.154289 zmwatch[3735].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/13 17:15:59.321079 zmwatch[3737].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/2013 17:16:06.155628 zmwatch[3735].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/13 17:16:09.322414 zmwatch[3737].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/2013 17:16:16.156992 zmwatch[3735].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/13 17:16:19.323772 zmwatch[3737].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/2013 17:16:26.158360 zmwatch[3735].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/13 17:16:29.325161 zmwatch[3737].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/2013 17:16:36.159748 zmwatch[3735].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
02/01/13 17:16:39.326492 zmwatch[3737].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
Posted: Tue Feb 05, 2013 11:15 am
by Jessminder
Hi I'm new on zm
I'm using Mepis 11 also and have the same problems than sealevelpete and the same logs.
02/05/13 11:24:19.499919 zmwatch[3050].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Any idea?
I have a Trendnet TV-IP551WI camera.
When I start zm I get this (not related?)
[root@mepis1 Jess]# /etc/init.d/zoneminder restart
Stopping ZoneMinder: sudo: unable to resolve host mepis1
success
Posted: Sat Apr 06, 2013 3:20 pm
by patman
I had the same issue.
My Solution was in the Apache Sites available. There was an ispconfig file 000-blablabla.
I delete this and its Running now
