[SOLVED] PTZ Camera Panasonic
Posted: Sun Jul 24, 2011 9:24 am
recently i installed ZoneMinder on Ubuntu 1.24.4 Desktop 11.04.
Everything works fine, I visualize my Panasonic camera, but I'm trying to move and does not work.
I looked at all the logs and no errors, the system does not show any error caused by access problems, reading, ....
I attached the file /usr/share/local/perl/5.10.1/ZoneMinder/Control/PanasonicIP.pm:
I active "control tab" and select "panasonic" in monitor options.
And i use in "Control Tab", field "Control Address": USER:PASS@IP:PORT, example: MYUSER:MYPASS@x.x.x.x:8088
I think problem is port.
Anyone help me? Thanks
# ZoneMinder Panasonic IP Control Protocol Module, $Date: 2008-07-25 10:48:16 +0100 (Fri, 25 Jul 2008) $, $Revision: 2612 $
# This module contains the implementation of the Panasonic IP camera control
# protocol
package ZoneMinder::Control::PanasonicIP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Panasonic IP Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub cameraReset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "nphRestart?PAGE=Restart&Restart=OK";
$self->sendCmd( $cmd );
sub moveConUp
my $self = shift;
Debug( "Move Up" );
my $cmd = "nphControlCamera?Direction=TiltUp";
sub moveConDown
my $self = shift;
Debug( "Move Down" );
my $cmd = "nphControlCamera?Direction=TiltDown";
sub moveConLeft
my $self = shift;
Debug( "Move Left" );
my $cmd = "nphControlCamera?Direction=PanLeft";
sub moveConRight
my $self = shift;
Debug( "Move Right" );
my $cmd = "nphControlCamera?Direction=PanRight";
sub moveMap
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
Debug( "Move Map to $xcoord,$ycoord" );
my $cmd = "nphControlCamera?Direction=Direct&NewPosition.x=$xcoord&NewPosition.y=$ycoord&Width=".$self->{Monitor}->{Width}."&Height=".$self->{Monitor}->{Height};
sub zoomConTele
my $self = shift;
my $params = shift;
my $step = $self->getParam( $params, 'step' );
Debug( "Zoom Tele" );
my $cmd = "nphControlCamera?Direction=ZoomTele";
sub zoomConWide
my $self = shift;
my $params = shift;
Debug( "Zoom Wide" );
my $cmd = "nphControlCamera?Direction=ZoomWide";
sub focusConNear
my $self = shift;
my $params = shift;
Debug( "Focus Near" );
my $cmd = "nphControlCamera?Direction=FocusNear";
sub focusConFar
my $self = shift;
my $params = shift;
Debug( "Focus Far" );
my $cmd = "nphControlCamera?Direction=FocusFar";
sub focusAuto
my $self = shift;
Debug( "Focus Auto" );
my $cmd = "nphControlCamera?Direction=FocusAuto";
sub focusMan
my $self = shift;
Debug( "Focus Manual" );
my $cmd = "/axis-cgi/com/ptz.cgi?autofocus=off";
sub presetClear
my $self = shift;
my $params = shift;
Debug( "Clear Preset $preset" );
my $cmd = "nphPresetNameCheck?Data=$preset";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "nphPresetNameCheck?PresetName=$preset&Data=$preset";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "nphControlCamera?Direction=Preset&PresetOperation=Move&Data=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "nphControlCamera?Direction=HomePosition";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
use ZoneMinder::Database;
blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
