Page 1 of 1
Split Image Problem On Monitor
Posted: Wed Jul 27, 2011 6:26 pm
by nabetse_x
Hi all,
I've been using Zoneminder a few years ago, and worked very well, recently understood a lot of configurations, but now i'm stuck with a problem that i can't resolve, 1 of my monitors have its image splited (attached still image) . With xawtv it looks great, but with Zoneminder this happens. Knows somebody how to fix this ?
Details of my installation :
Pc : Intel Pentium 4 3.00 Ghz CPU
Ram : 1024 MB
Video Card : Nvidia Geforce 4 MX 4000 AGP
OS : Ubuntu 10.04 LTS (miss some updates)
Zoneminder Versión : 1.24.2
DVR card PICO 4 Channel PCI (about 5 years old)
Camera : Samsung SDC-415
Configuration on Zoneminder :
Device Path : /dev/video0 channel 3
Capture Method : Video for linux 2
Format : NTSC
Palette : RGB565
W x H : 320x240 pix
Using Passive Balun with UTP Cat-5e Cable, about 60 mts.
If anyone can help me please, ive tryied different methods of configuration, and won't work.
Thanks in advance.
Note : sorry, my english sucks, i'm from Chile
Español :
Buenas.
he estado usando Zoneminder hace unos años y ha funcionado bastante bien, recientemente he entendido varias de sus configuraciones, pero ahora me encuentro detenido con un problema que no puedo resolver, 1 de mis monitores tiene la imagen dividida (adjunto imagen). Con xawtv funciona perfecto, pero esto pasa con Zoneminder, Sabe alguien como arreglar esto ??
Detalles de Mi Instalación :
Ram : 1024 MB
Format : NTSC
Palette : RGB565
W x H : 320x240 pix
Si alguien porfavor puede ayudarme, he intentado diferentes metodos de configuracion y no funciona.
Gracias , de antemano.
Re: Split Image Problem On Monitor
Posted: Wed Jul 27, 2011 11:06 pm
by bb99
Check "CAPTURES_PER_FRAME" setting (options::config). Or possibly disable "V4L_MULTI_BUFFER" (options::config). If neither of these fix the problem try Video for Linux 1 in the monitor source settings. One more thing I just noticed, try changing the palette to BGR24 unless your sure the one selected is correct (palettes seem to have changed with 1.24.2).
Posted: Thu Jul 28, 2011 12:31 am
by nabetse_x
Thanks bb99, tomorrow i will try this.
But anyway , thanks.
Posted: Thu Jul 28, 2011 1:35 am
by bb99
Just realised I never gave you a value for "CAPTURES_PER_FRAME", it should be 2 or possibly 3. Be patient in between changes, takes awhile to actually see the change after save.
Posted: Thu Jul 28, 2011 8:38 am
by TucsonDirect
the way fixed this problem was to....(in ver 1.22.2)
1. Make sure all monitor settings on the card in use are the same (i.e. resolution, FPS, ....)
2. Set max FPS to 2 or 3 On ALL 4 channels
3. Click on "Running" and restart the service (not the DVR)
4. Connect Cameras to all 4 ports
this has always resolved my problem and then i could increase the fps to 3 or 4.
also under EACH camera settings go to "BUFFERS" and set the following settings(will also reduce cpu load as well as help resolve the problem)
Image Buffer Size (frames) 20
Warmup Frames 10
Pre Event Image Buffer 10
Post Event Image Buffer 10
Alarm Frame Count 1
Posted: Thu Jul 28, 2011 1:26 pm
by nabetse_x
Thanks for your help,
i've just applied the settings , anything i'll post it here.
Best Regards.
Posted: Thu Jul 28, 2011 10:18 pm
by nabetse_x
after a complete day testing , i can say that it works...
thanks for your help, now i can Modect ... :D
Bye.
Posted: Fri Jul 29, 2011 2:38 am
by bb99
Perfect! Please edit the title to include "solved", makes searches easier for the next person with the same problem.
Posted: Sat Jul 30, 2011 6:13 am
by TucsonDirect
Glad i could help! :P
Your next priority should be to get rid of that Cheap China Card and get something nice..... or keep it for the cams that arent imporant. :!:
For Future forum visitors Which solution solved your problem?
