Eventually I'm trying to get LDAP authentication to work using remote auth, but for now even with a simple AuthUserFile setup in a .htaccess file in the top level /var/www/html/zm directory, the login page keeps reloading over and over again after I login in the Apache authentication window. I've tried setting it to use remote auth with both plain and hashed AUTH_RELAY, but I get the same result where it says "Logging in.." and that page keeps reloading itself. I've also tried setting the user in the zm database to have no password and removing the user completely but same results there.
Using 1.24.4, here's my .htaccess file under /var/www/html/zm :
AuthName 'ZM, enter your login and password'
AuthType Basic
AuthUserFile /home/me/htpasswd
Require valid-user
<Directory "/var/www/html/zm">
Options FollowSymLinks
AllowOverride All
</Directory>
<Directory "/var/www/html/zm/cgi-bin">
SetHandler cgi-script
AllowOverride All
</Directory>
Using CENTOS 6.
Any Ideas?
Thanks,
Sabuj
