I have problem with zm while I want to watch already recorded shots.
On CentOS 5.6 everything worked fine, but recently I installed Centos 6.0 from scratch and problems started. (as same as on 5.6 everything what required is installed from rpmforge except zm which is compiled by me).
After opening recorded event video it hangs (no matter if using flash or java), and I'm getting this error in apache's error log:
[Tue Aug 09 10:08:53 2011] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.2 configured -- resuming normal operations
[Tue Aug 09 10:13:32 2011] [error] [client 10.0.0.153] socket_sendto( /tmp/zm/zms-374709s.sock ) failed: No such file or directory, referer: xxxx://10.0.0.13/zm/index.php?view=event&eid=965&trms=1&attr1=MonitorId&op1=%3d&val1=1&page=1
[Tue Aug 09 10:13:32 2011] [error] [client 10.0.0.153] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zm/zms-374709s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 121,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: xxx://10.0.0.13/zm/index.php?view=event&eid=965&trms=1&attr1=MonitorId&op1=%3d&val1=1&page=1
I've check /tmp /zm for right chmod and it's 777 so it shouldn't be a problem.
What else could I try?
