If I view montage etc then I can see the web page but if I try to load the default page http://myserver/zm
I get this…
An error has occurred and this operation cannot continue.
For full details check your web logs for the code '651AC7'
Running on Debian Squeeze…
was OK now not...
Odd Problem
- zoneminder
- Site Admin
- Contact:
Re: Odd Problem
If you search for that code in your web logs you should see some more information.
Phil
Re: Odd Problem
OK looks like an SQL error…zoneminder wrote:If you search for that code in your web logs you should see some more information.
how do I repair this ?
[Tue Aug 09 20:49:38 2011] [error] [client 88.97.139.138] SQL-ERROR(B36C5F): Table 'Events' is marked as crashed and should be repaired
