ACTi ACD-2300
josh.k.abbott
ACTi ACD-2300
Post by josh.k.abbott »
Hi
I'm trying to use an ACTi ACD-2300 8-channel MPEG-4 1U Video Encoder with zoneminder.
I'm currently having a problem with zoneminder not recognizing the video stream.
With VLC I can see the stream, using the following address:
http : / / ***:***@x . x . x . x:800/cgi-bin/cmd/encoder?GET_STREAM
When configuring in ZM the monitor stays green but doesn't show any image when using the live function.
After enabling debug mode I can see the following being repeated all the time:
08/12/11 15:02:18.420274 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/196 [Read 77 bytes]
08/12/11 15:02:18.420289 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/885 [Unable to extract subheader from stream, retrying]
08/12/11 15:02:18.420918 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/171 [Expecting 1330 bytes]
08/12/11 15:02:18.420949 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/196 [Read 1330 bytes]
08/12/11 15:02:18.420970 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/885 [Unable to extract subheader from stream, retrying]
08/12/11 15:02:18.499447 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/171 [Expecting 77 bytes]
08/12/11 15:02:18.499489 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/196 [Read 77 bytes]
08/12/11 15:02:18.499509 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/885 [Unable to extract subheader from stream, retrying]
08/12/11 15:02:18.500543 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/171 [Expecting 1607 bytes]
The ACTi is configured in MPEG4 mode, when I set it in MJPEG the result is the same.
I have other camera working in ZM.
Is this encoder incompatible with zm? Or is there something I'm missing?
Thank you
josh
