Hi all,
I have spent a lot of time trying to setup ZM and I am almost there apart from the webcam images misbehaving.
I am using the microsoft lifecam VX 6000
and the Philips ToUcam Pro
I setup all possible combinations in the palette and I still get either blank, non-functioning images or of the type attached below. I know I am getting close because when I move in front of the camera the image moves too, it's just that it is not proper as you can see.
I search the specs of both cameras and ToUCam Pro is a YUV420. I am not sure what the Microsoft camera is using, but still, as I said, I tried almost all combos.
Any suggestions in how to get it to work? How to fix it? When I try to capture images with streamer or xawtv it works fine which is very puzzling.
...and when I run:
sudo zmu -d /dev/video1 -q -v -V1
I get:
Video Device: /dev/video1
Video Capabilities
Name: Philips 740 webcam
Type: 1
Can capture
Video Channels: 1
Audio Channels: 1
Maximum Width: 640
Maximum Height: 480
Minimum Width: 160
Minimum Height: 120
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 15 - YUV 4:2:0 Planar
Colour Depth: 24
Brightness: 32256
Hue: 65535
Colour :16091
Contrast: 20480
Whiteness: 10240
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 49111 - Unknown
I am running Ubuntu 9.10 server. Any ideas?
Thanks in advance.
Image problems - Please help!!
- screen_sample1.png (64.8 KiB) Viewed 732 times
