Crashes on attempting to add H.264 Axis & Messoa cameras
Renmess
Post by Renmess »
I have been trying unsuccessfully to add two cameras to ZoneMinder 1.24.2. I wish to use the H.264 RTSP streams for these cameras. The URLs given below in the debug output below both work solid in VLC, but I cannot figure out why they are not working in ZoneMinder.
I have built the x264 library and ffmpeg with H.264 as well:
root@griffin:/var/log# ffmpeg -codecs | egrep 'libx264'
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
built on Aug 19 2011 20:43:47 with gcc 4.5.2
configuration: --enable-gpl --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavcodec 52.108. 0 / 52.108. 0
libavformat 52.93. 0 / 52.93. 0
libavdevice 52. 2. 3 / 52. 2. 3
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
libpostproc 51. 2. 0 / 51. 2. 0
EV libx264 libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
I'm adding the cameras like so:
[Messoa]
Source Type: Ffmpeg
Source Path: rtsp://10.0.0.239:8557/h264
Source Colours: 24 bit colour
Capture Width: 1920
Capture Height: 1080
[Axis]
Source Type: Ffmpeg
Source Path: rtsp://root:pass@10.0.0.63/axis-media/media.amp
Capture Width: 1280
Capture Height: 800
Crash:
/var/log# *** glibc detected *** /usr/bin/zmc: double free or corruption (!prev): 0x0000000007ef0ce0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x78a8f)[0x7f39bff29a8f]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x73)[0x7f39bff2d8e3]
/usr/lib/libavformat.so.52(av_close_input_stream+0x84)[0x7f39c24dd004]
/usr/bin/zmc[0x41a838]
/usr/bin/zmc[0x41a904]
/usr/bin/zmc[0x42c2a2]
/usr/bin/zmc[0x406ecf]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff)[0x7f39bfecfeff]
/usr/bin/zmc[0x405f79]
======= Memory map: ========
00400000-00489000 r-xp 00000000 08:01 2371681 /usr/bin/zmc
00688000-00689000 r--p 00088000 08:01 2371681 /usr/bin/zmc
00689000-0068b000 rw-p 00089000 08:01 2371681 /usr/bin/zmc
0068b000-060ec000 rw-p 00000000 00:00 0
07ec2000-08e26000 rw-p 00000000 00:00 0 [heap]
7f39a4000000-7f39a4021000 rw-p 00000000 00:00 0
7f39a4021000-7f39a8000000 ---p 00000000 00:00 0
7f39ab39d000-7f39abf7b000 rw-p 00000000 00:00 0
7f39ac371000-7f39bb0c0000 rw-s 00000000 00:04 294913 /SYSV7a6d0001 (deleted)
7f39bb0c0000-7f39bbc9e000 rw-p 00000000 00:00 0
7f39bc28d000-7f39bc299000 r-xp 00000000 08:01 10223825 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f39bc299000-7f39bc498000 ---p 0000c000 08:01 10223825 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f39bc498000-7f39bc499000 r--p 0000b000 08:01 10223825 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f39bc499000-7f39bc49a000 rw-p 0000c000 08:01 10223825 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f39bc49a000-7f39bc49d000 r-xp 00000000 08:01 10224427 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0
7f39bc49d000-7f39bc69c000 ---p 00003000 08:01 10224427 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0
7f39bc69c000-7f39bc69d000 r--p 00002000 08:01 10224427 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0
7f39bc69d000-7f39bc69e000 rw-p 00003000 08:01 10224427 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0
7f39bc69e000-7f39bc6a4000 r-xp 00000000 08:01 2370035 /usr/lib/libogg.so.0.7.0
7f39bc6a4000-7f39bc8a3000 ---p 00006000 08:01 2370035 /usr/lib/libogg.so.0.7.0
7f39bc8a3000-7f39bc8a4000 r--p 00005000 08:01 2370035 /usr/lib/libogg.so.0.7.0
7f39bc8a4000-7f39bc8a5000 rw-p 00006000 08:01 2370035 /usr/lib/libogg.so.0.7.0
7f39bc8a5000-7f39bc91b000 r-xp 00000000 08:01 2365961 /usr/lib/liborc-0.4.so.0.11.0
7f39bc91b000-7f39bcb1a000 ---p 00076000 08:01 2365961 /usr/lib/liborc-0.4.so.0.11.0
7f39bcb1a000-7f39bcb1c000 r--p 00075000 08:01 2365961 /usr/lib/liborc-0.4.so.0.11.0
7f39bcb1c000-7f39bcb20000 rw-p 00077000 08:01 2365961 /usr/lib/liborc-0.4.so.0.11.0
7f39bcb20000-7f39bcb22000 r-xp 00000000 08:01 10223818 /lib/x86_64-linux-gnu/libdl-2.13.so
7f39bcb22000-7f39bcd22000 ---p 00002000 08:01 10223818 /lib/x86_64-linux-gnu/libdl-2.13.so
7f39bcd22000-7f39bcd23000 r--p 00002000 08:01 10223818 /lib/x86_64-linux-gnu/libdl-2.13.so
7f39bcd23000-7f39bcd24000 rw-p 00003000 08:01 10223818 /lib/x86_64-linux-gnu/libdl-2.13.so
7f39bcd24000-7f39bcd9a000 r-xp 00000000 08:01 10224433 /lib/x86_64-linux-gnu/libgcrypt.so.11.6.0
7f39bcd9a000-7f39bcf9a000 ---p 00076000 08:01 10224433 /lib/x86_64-linux-gnu/libgcrypt.so.11.6.0
7f39bcf9a000-7f39bcf9b000 r--p 00076000 08:01 10224433 /lib/x86_64-linux-gnu/libgcrypt.so.11.6.0
7f39bcf9b000-7f39bcf9e000 rw-p 00077000 08:01 10224433 /lib/x86_64-linux-gnu/libgcrypt.so.11.6.0
7f39bcf9e000-7f39bd038000 r-xp 00000000 08:01 2360879 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.14.12
7f39bd038000-7f39bd238000 ---p 0009a000 08:01 2360879 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.14.12
7f39bd238000-7f39bd23e000 r--p 0009a000 08:01 2360879 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.14.12
7f39bd23e000-7f39bd23f000 rw-p 000a0000 08:01 2360879 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.14.12
7f39bd23f000-7f39bd24e000 r-xp 00000000 08:01 2360075 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.9
7f39bd24e000-7f39bd44e000 ---p 0000f000 08:01 2360075 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.9
7f39bd44e000-7f39bd44f000 r--p 0000f000 08:01 2360075 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.9
7f39bd44f000-7f39bd450000 rw-p 00010000 08:01 2360075 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.9
7f39bd450000-7f39bd4e9000 r-xp 00000000 08:01 2371667 /usr/lib/libxvidcore.so.4.2
7f39bd4e9000-7f39bd6e9000 ---p 00099000 08:01 2371667 /usr/lib/libxvidcore.so.4.2
7f39bd6e9000-7f39bd6ea000 r--p 00099000 08:01 2371667 /usr/lib/libxvidcore.so.4.2
7f39bd6ea000-7f39bd6f4000 rw-p 0009a000 08:01 2371667 /usr/lib/libxvidcore.so.4.2
7f39bd6f4000-7f39bd75e000 rw-p 00000000 00:00 0
7f39bd75e000-7f39bd82d000 r-xp 00000000 08:01 2371666 /usr/lib/libx264.so.106
7f39bd82d000-7f39bda2c000 ---p 000cf000 08:01 2371666 /usr/lib/libx264.so.106
7f39bda2c000-7f39bda2e000 r--p 000ce000 08:01 2371666 /usr/lib/libx264.so.106
7f39bda2e000-7f39bda2f000 rw-p 000d0000 08:01 2371666 /usr/lib/libx264.so.106
7f39bda2f000-7f39bda36000 rw-p 00000000 00:00 0
7f39bda36000-7f39bdacb000 r-xp 00000000 08:01 2366029 /usr/lib/libvpx.so.0.9.6
7f39bdacb000-7f39bdcca000 ---p 00095000 08:01 2366029 /usr/lib/libvpx.so.0.9.6
7f39bdcca000-7f39bdccc000 r--p 00094000 08:01 2366029 /usr/lib/libvpx.so.0.9.6
7f39bdccc000-7f39bdccd000 rw-p 00096000 08:01 2366029 /usr/lib/libvpx.so.0.9.6
7f39bdccd000-7f39bdcd7000 rw-p 00000000 00:00 0
7f39bdcd7000-7f39bdd02000 r-xp 00000000 08:01 2362621 /usr/lib/libvorbis.so.0.4.5
7f39bdd02000-7f39bdf01000 ---p 0002b000 08:01 2362621 /usr/lib/libvorbis.so.0.4.5
7f39bdf01000-7f39bdf02000 r--p 0002a000 08:01 2362621 /usr/lib/libvorbis.so.0.4.5
7f39bdf02000-7f39bdf03000 rw-p 0002b000 08:01 2362621 /usr/lib/libvorbis.so.0.4.5
7f39bdf03000-7f39be1b6000 r-xp 00000000 08:01 2362602 /usr/lib/libvorbisenc.so.2.0.8
7f39be1b6000-7f39be3b5000 ---p 002b3000 08:01 2362602 /usr/lib/libvorbisenc.so.2.0.8
Syslog output:
Aug 20 22:26:20 griffin zmwatch[14113]: INF [Restarting capture daemon for Axis-1, time since last capture 9 seconds (1313904380-1313904371)]
Aug 20 22:26:21 griffin zmdc[14068]: INF ['zmc -m 2' stopping at 11/08/20 22:26:21]
Aug 20 22:26:21 griffin zmc_m2[14104]: INF [Got signal 15 (Terminated), exiting]
Aug 20 22:26:27 griffin zmdc[14068]: INF ['zmc -m 2' crashed, signal 8]
Aug 20 22:26:27 griffin zmwatch[14113]: INF ['zmc -m 2' stopping at 11/08/20 22:26:21]
Aug 20 22:26:27 griffin zmdc[14068]: INF [Starting pending process, zmc -m 2]
Aug 20 22:26:27 griffin zmdc[14068]: INF ['zmc -m 2' starting at 11/08/20 22:26:27, pid = 14194]
Aug 20 22:26:27 griffin zmdc[14194]: INF ['zmc -m 2' started at 11/08/20 22:26:27]
Aug 20 22:26:27 griffin zmc_m2[14194]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 22:26:27 griffin zmc_m2[14194]: INF [Starting Capture]
Aug 20 22:26:27 griffin zmc_m2[14194]: INF [Priming capture from rtsp://root:pass@10.0.0.63/axis-media/media.amp]
Aug 20 22:26:47 griffin zmdc[14068]: INF ['zmc -m 2' stopping at 11/08/20 22:26:47]
Aug 20 22:26:47 griffin zmc_m2[14194]: INF [Got signal 15 (Terminated), exiting]
Aug 20 22:26:53 griffin zmdc[14068]: INF ['zmc -m 2' crashed, signal 8]
Aug 20 22:26:53 griffin zmdc[14068]: INF ['zmc -m 2' starting at 11/08/20 22:26:53, pid = 14231]
Aug 20 22:26:53 griffin zmdc[14231]: INF ['zmc -m 2' started at 11/08/20 22:26:53]
Aug 20 22:26:53 griffin zmc_m2[14231]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 22:26:54 griffin zmdc[14068]: WAR [Can't find process with command of 'zma -m 2']
Aug 20 22:26:54 griffin zmc_m2[14231]: INF [Starting Capture]
Aug 20 22:26:54 griffin zmc_m2[14231]: INF [Priming capture from rtsp://root:pass@10.0.0.63/axis-media/media.amp]
Aug 20 22:27:14 griffin zmc_m1[14144]: INF [Messoa-1: 2000 - Capturing at 15.15 fps]
Aug 20 22:28:20 griffin zmc_m1[14144]: INF [Messoa-1: 3000 - Capturing at 15.15 fps]
Aug 20 22:28:22 griffin zmpkg[14498]: INF [Command: status]
Aug 20 22:28:22 griffin zmpkg[14504]: INF [Command: stop]
Aug 20 22:28:23 griffin zmdc[14068]: INF ['zmc -m 1' stopping at 11/08/20 22:28:23]
Aug 20 22:28:23 griffin zmc_m1[14144]: INF [Got signal 15 (Terminated), exiting]
Aug 20 22:28:29 griffin zmdc[14068]: INF ['zmc -m 1' crashed, signal 8]
Aug 20 22:28:29 griffin zmdc[14068]: INF ['zmwatch.pl ' stopping at 11/08/20 22:28:29]
Aug 20 22:28:29 griffin zmdc[14068]: INF ['zmwatch.pl ' exited, signal 14]
Aug 20 22:28:29 griffin zmdc[14068]: INF ['zmfilter.pl ' stopping at 11/08/20 22:28:29]
Aug 20 22:28:29 griffin zmdc[14068]: INF ['zmfilter.pl ' exited, signal 14]
Aug 20 22:28:29 griffin zmdc[14068]: INF ['zmc -m 2' stopping at 11/08/20 22:28:29]
Aug 20 22:28:29 griffin zmc_m2[14231]: INF [Got signal 15 (Terminated), exiting]
Aug 20 22:28:35 griffin zmdc[14068]: INF ['zmc -m 2' crashed, signal 8]
Aug 20 22:28:35 griffin zmdc[14068]: INF ['zmaudit.pl -c' stopping at 11/08/20 22:28:35]
Aug 20 22:28:35 griffin zmdc[14068]: INF ['zmaudit.pl -c' exited, signal 14]
Aug 20 22:28:45 griffin zmdc[14068]: INF [Server shutdown at 11/08/20 22:28:45]
Aug 20 22:28:45 griffin zmpkg[14577]: INF [Command: start]
Aug 20 22:28:45 griffin zmdc[14590]: INF [Server starting at 11/08/20 22:28:45]
Aug 20 22:28:48 griffin zmdc[14590]: INF ['zmc -m 1' starting at 11/08/20 22:28:48, pid = 14617]
Aug 20 22:28:48 griffin zmdc[14617]: INF ['zmc -m 1' started at 11/08/20 22:28:48]
Aug 20 22:28:48 griffin zmc_m1[14617]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 22:28:48 griffin zmdc[14590]: INF ['zmc -m 2' starting at 11/08/20 22:28:48, pid = 14620]
Aug 20 22:28:48 griffin zmdc[14620]: INF ['zmc -m 2' started at 11/08/20 22:28:48]
Aug 20 22:28:48 griffin zmc_m2[14620]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 22:28:49 griffin zmc_m1[14617]: INF [Starting Capture]
Aug 20 22:28:49 griffin zmc_m1[14617]: INF [Priming capture from rtsp://10.0.0.239:8557/h264]
Aug 20 22:28:49 griffin zmdc[14590]: INF ['zmfilter.pl' starting at 11/08/20 22:28:49, pid = 14623]
Aug 20 22:28:49 griffin zmdc[14623]: INF ['zmfilter.pl' started at 11/08/20 22:28:49]
Aug 20 22:28:49 griffin zmc_m2[14620]: INF [Starting Capture]
Aug 20 22:28:49 griffin zmc_m2[14620]: INF [Priming capture from rtsp://root:pass@10.0.0.63/axis-media/media.amp]
Aug 20 22:28:49 griffin zmdc[14590]: INF ['zmaudit.pl -c' starting at 11/08/20 22:28:49, pid = 14626]
Aug 20 22:28:49 griffin zmdc[14626]: INF ['zmaudit.pl -c' started at 11/08/20 22:28:49]
Aug 20 22:28:49 griffin zmfilter[14623]: INF [Scanning for events]
Aug 20 22:28:49 griffin zmdc[14590]: INF ['zmwatch.pl' starting at 11/08/20 22:28:49, pid = 14629]
Aug 20 22:28:49 griffin zmdc[14629]: INF ['zmwatch.pl' started at 11/08/20 22:28:49]
Aug 20 22:28:49 griffin zmwatch[14629]: INF [Watchdog starting]
Aug 20 22:28:49 griffin zmwatch[14629]: INF [Watchdog pausing for 30 seconds]
Aug 20 22:28:59 griffin zmdc[14590]: INF ['zmc -m 1' stopping at 11/08/20 22:28:59]
Aug 20 22:28:59 griffin zmc_m1[14617]: INF [Got signal 15 (Terminated), exiting]
Aug 20 22:29:05 griffin zmdc[14590]: INF ['zmc -m 1' crashed, signal 8]
Aug 20 22:29:05 griffin zmdc[14590]: INF ['zmc -m 1' starting at 11/08/20 22:29:05, pid = 14647]
Aug 20 22:29:05 griffin zmdc[14647]: INF ['zmc -m 1' started at 11/08/20 22:29:05]
Aug 20 22:29:05 griffin zmc_m1[14647]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 22:29:05 griffin zmdc[14590]: WAR [Can't find process with command of 'zma -m 1']
Aug 20 22:29:05 griffin zmc_m1[14647]: INF [Starting Capture]
Aug 20 22:29:05 griffin zmc_m1[14647]: INF [Priming capture from rtsp://10.0.0.239:8557/h264
All advice appreciated.
Renmess
More debug output
Post by Renmess »
Here's some additional debug output after turning on debug level 5:
zmwatch:
08/19/2011 18:47:58.688963 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:48:08.689973 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:48:18.690647 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:48:28.691337 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:48:38.691967 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:48:48.692637 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:48:58.693326 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:49:08.694011 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:49:18.694694 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:49:28.695557 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:49:38.696245 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:49:48.696904 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:49:58.697585 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:50:08.698491 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:50:18.699430 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:50:28.700110 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:50:38.700779 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:50:48.701416 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:50:58.702057 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:51:08.702672 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:51:18.703309 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:51:28.703979 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:51:38.704665 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:51:48.705364 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:51:58.706030 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:52:08.706679 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:52:18.707289 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:52:28.707948 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:52:38.708642 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:52:48.709326 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 18:52:58.710020 zmwatch[10294].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
[Many such lines]]
8/19/2011 21:13:32.105043 zmwatch[13436].INF [Watchdog starting]
08/19/2011 21:13:32.105205 zmwatch[13436].INF [Watchdog pausing for 30 seconds]
08/19/2011 21:14:02.106615 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:14:12.107315 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:14:22.108001 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:14:32.108609 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:14:42.109254 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:14:52.109948 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:15:02.110605 zmwatch[13436].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:15:17.658467 zmwatch[13705].INF [Watchdog starting]
08/19/2011 21:15:17.658633 zmwatch[13705].INF [Watchdog pausing for 30 seconds]
08/19/2011 21:15:47.659956 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:15:57.660646 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:16:07.661299 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:16:17.661967 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:16:27.662656 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:16:37.663353 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:16:47.664061 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:16:57.664676 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:17:07.665351 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:17:17.666003 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:17:27.666623 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:17:37.667270 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:17:47.667946 zmwatch[13705].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/19/2011 21:41:07.760214 zmwatch[13705].INF [Restarting capture daemon for Messoa-1, time since last capture 8 seconds (1313815267-1313815259)]
08/19/2011 21:41:13.865837 zmwatch[13705].INF ['zmc -m 1' stopping at 11/08/19 21:41:07]
08/19/2011 22:04:43.952184 zmwatch[13705].INF [Restarting capture daemon for Messoa-1, time since last capture 8 seconds (1313816683-1313816675)]
08/19/2011 22:04:50.061231 zmwatch[13705].INF ['zmc -m 1' stopping at 11/08/19 22:04:44]
08/19/2011 22:05:00.062250 zmwatch[13705].INF [Restarting capture daemon for Messoa-1, time since last capture 14 seconds (1313816700-1313816686)]
08/19/2011 22:05:00.171064 zmwatch[13705].INF ['zmc -m 1' starting at 11/08/19 22:05:00, pid = 18614]
08/20/2011 22:19:00.777793 zmwatch[13300].INF [Watchdog starting]
08/20/2011 22:19:00.778013 zmwatch[13300].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:22:53.996243 zmwatch[13649].INF [Watchdog starting]
08/20/2011 22:22:53.996411 zmwatch[13649].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:24:08.695811 zmwatch[13987].INF [Watchdog starting]
08/20/2011 22:24:08.695981 zmwatch[13987].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:24:40.978712 zmwatch[14113].INF [Watchdog starting]
08/20/2011 22:24:40.978876 zmwatch[14113].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:26:20.987168 zmwatch[14113].INF [Restarting capture daemon for Axis-1, time since last capture 9 seconds (1313904380-1313904371)]
08/20/2011 22:26:27.110697 zmwatch[14113].INF ['zmc -m 2' stopping at 11/08/20 22:26:21]
08/20/2011 22:28:49.413254 zmwatch[14629].INF [Watchdog starting]
08/20/2011 22:28:49.413422 zmwatch[14629].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:35:26.174501 zmwatch[15259].INF [Watchdog starting]
08/20/2011 22:35:26.174661 zmwatch[15259].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:36:49.933905 zmwatch[15413].INF [Watchdog starting]
08/20/2011 22:36:49.934071 zmwatch[15413].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:38:18.159539 zmwatch[15737].INF [Watchdog starting]
08/20/2011 22:38:18.159703 zmwatch[15737].INF [Watchdog pausing for 30 seconds]
08/20/2011 22:39:38.166681 zmwatch[15737].INF [Restarting capture daemon for Axis-1, time since last capture 9 seconds (1313905178-1313905169)]
08/20/2011 22:39:39.297981 zmwatch[15737].INF ['zmc -m 2' stopping at 11/08/20 22:39:38]
08/20/2011 22:43:49.320854 zmwatch[15737].INF [Restarting capture daemon for Axis-1, time since last capture 10 seconds (1313905429-1313905419)]
08/20/2011 22:43:55.426850 zmwatch[15737].INF ['zmc -m 2' stopping at 11/08/20 22:43:49]
zmdc.log:
8/20/2011 22:24:40.796359 zmdc[14068].INF ['zmaudit.pl -c' starting at 11/08/20 22:24:40, pid = 14110]
08/20/2011 22:24:40.895289 zmdc[14068].INF ['zmwatch.pl' starting at 11/08/20 22:24:40, pid = 14113]
08/20/2011 22:24:54.596105 zmdc[14068].INF ['zmc -m 1' stopping at 11/08/20 22:24:54]
08/20/2011 22:25:00.613131 zmdc[14068].INF ['zmc -m 1' crashed, signal 8]
08/20/2011 22:25:00.724746 zmdc[14068].INF ['zmc -m 1' starting at 11/08/20 22:25:00, pid = 14144]
08/20/2011 22:25:00.815416 zmdc[14068].WAR [Can't find process with command of 'zma -m 1']
08/20/2011 22:26:21.102508 zmdc[14068].INF ['zmc -m 2' stopping at 11/08/20 22:26:21]
08/20/2011 22:26:27.108369 zmdc[14068].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:26:27.208800 zmdc[14068].INF [Starting pending process, zmc -m 2]
08/20/2011 22:26:27.209498 zmdc[14068].INF ['zmc -m 2' starting at 11/08/20 22:26:27, pid = 14194]
08/20/2011 22:26:47.819091 zmdc[14068].INF ['zmc -m 2' stopping at 11/08/20 22:26:47]
08/20/2011 22:26:53.829268 zmdc[14068].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:26:53.926357 zmdc[14068].INF ['zmc -m 2' starting at 11/08/20 22:26:53, pid = 14231]
08/20/2011 22:26:54.020978 zmdc[14068].WAR [Can't find process with command of 'zma -m 2']
08/20/2011 22:28:23.196953 zmdc[14068].INF ['zmc -m 1' stopping at 11/08/20 22:28:23]
08/20/2011 22:28:29.220743 zmdc[14068].INF ['zmc -m 1' crashed, signal 8]
08/20/2011 22:28:29.220996 zmdc[14068].INF ['zmwatch.pl ' stopping at 11/08/20 22:28:29]
08/20/2011 22:28:29.222399 zmdc[14068].INF ['zmwatch.pl ' exited, signal 14]
08/20/2011 22:28:29.222558 zmdc[14068].INF ['zmfilter.pl ' stopping at 11/08/20 22:28:29]
08/20/2011 22:28:29.224696 zmdc[14068].INF ['zmfilter.pl ' exited, signal 14]
08/20/2011 22:28:29.224864 zmdc[14068].INF ['zmc -m 2' stopping at 11/08/20 22:28:29]
08/20/2011 22:28:35.232429 zmdc[14068].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:28:35.232716 zmdc[14068].INF ['zmaudit.pl -c' stopping at 11/08/20 22:28:35]
08/20/2011 22:28:35.234273 zmdc[14068].INF ['zmaudit.pl -c' exited, signal 14]
08/20/2011 22:28:45.344691 zmdc[14068].INF [Server shutdown at 11/08/20 22:28:45]
08/20/2011 22:28:45.775321 zmdc[14590].INF [Server starting at 11/08/20 22:28:45]
08/20/2011 22:28:48.881439 zmdc[14590].INF ['zmc -m 1' starting at 11/08/20 22:28:48, pid = 14617]
08/20/2011 22:28:48.982825 zmdc[14590].INF ['zmc -m 2' starting at 11/08/20 22:28:48, pid = 14620]
08/20/2011 22:28:49.134241 zmdc[14590].INF ['zmfilter.pl' starting at 11/08/20 22:28:49, pid = 14623]
08/20/2011 22:28:49.231264 zmdc[14590].INF ['zmaudit.pl -c' starting at 11/08/20 22:28:49, pid = 14626]
08/20/2011 22:28:49.330926 zmdc[14590].INF ['zmwatch.pl' starting at 11/08/20 22:28:49, pid = 14629]
08/20/2011 22:28:59.680373 zmdc[14590].INF ['zmc -m 1' stopping at 11/08/20 22:28:59]
08/20/2011 22:29:05.697406 zmdc[14590].INF ['zmc -m 1' crashed, signal 8]
08/20/2011 22:29:05.800470 zmdc[14590].INF ['zmc -m 1' starting at 11/08/20 22:29:05, pid = 14647]
08/20/2011 22:29:05.898233 zmdc[14590].WAR [Can't find process with command of 'zma -m 1']
08/20/2011 22:34:59.960782 zmdc[14590].INF ['zmaudit.pl -c' stopping at 11/08/20 22:34:59]
08/20/2011 22:34:59.961948 zmdc[14590].INF ['zmaudit.pl -c' exited, signal 14]
08/20/2011 22:34:59.962099 zmdc[14590].INF ['zmc -m 1' stopping at 11/08/20 22:34:59]
08/20/2011 22:35:05.984155 zmdc[14590].INF ['zmc -m 1' crashed, signal 8]
08/20/2011 22:35:05.984445 zmdc[14590].INF ['zmwatch.pl ' stopping at 11/08/20 22:35:05]
08/20/2011 22:35:05.985821 zmdc[14590].INF ['zmwatch.pl ' exited, signal 14]
08/20/2011 22:35:05.986012 zmdc[14590].INF ['zmfilter.pl ' stopping at 11/08/20 22:35:05]
08/20/2011 22:35:05.988081 zmdc[14590].INF ['zmfilter.pl ' exited, signal 14]
08/20/2011 22:35:05.988275 zmdc[14590].INF ['zmc -m 2' stopping at 11/08/20 22:35:05]
08/20/2011 22:35:11.995542 zmdc[14590].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:35:22.104957 zmdc[14590].INF [Server shutdown at 11/08/20 22:35:22]
08/20/2011 22:35:22.536689 zmdc[15223].INF [Server starting at 11/08/20 22:35:22]
08/20/2011 22:35:25.638231 zmdc[15223].INF ['zmc -m 1' starting at 11/08/20 22:35:25, pid = 15247]
08/20/2011 22:35:25.748036 zmdc[15223].INF ['zmc -m 2' starting at 11/08/20 22:35:25, pid = 15250]
08/20/2011 22:35:25.894489 zmdc[15223].INF ['zmfilter.pl' starting at 11/08/20 22:35:25, pid = 15253]
08/20/2011 22:35:25.991458 zmdc[15223].INF ['zmaudit.pl -c' starting at 11/08/20 22:35:25, pid = 15256]
08/20/2011 22:35:26.091430 zmdc[15223].INF ['zmwatch.pl' starting at 11/08/20 22:35:26, pid = 15259]
08/20/2011 22:36:23.771165 zmdc[15223].INF ['zmaudit.pl -c' stopping at 11/08/20 22:36:23]
08/20/2011 22:36:23.772791 zmdc[15223].INF ['zmaudit.pl -c' exited, signal 14]
08/20/2011 22:36:23.772994 zmdc[15223].INF ['zmc -m 2' stopping at 11/08/20 22:36:23]
08/20/2011 22:36:29.780207 zmdc[15223].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:36:29.780499 zmdc[15223].INF ['zmwatch.pl ' stopping at 11/08/20 22:36:29]
08/20/2011 22:36:29.781881 zmdc[15223].INF ['zmwatch.pl ' exited, signal 14]
08/20/2011 22:36:29.782078 zmdc[15223].INF ['zmc -m 1' stopping at 11/08/20 22:36:29]
08/20/2011 22:36:35.796857 zmdc[15223].INF ['zmc -m 1' crashed, signal 8]
08/20/2011 22:36:35.797146 zmdc[15223].INF ['zmfilter.pl ' stopping at 11/08/20 22:36:35]
08/20/2011 22:36:35.799261 zmdc[15223].INF ['zmfilter.pl ' exited, signal 14]
08/20/2011 22:36:45.908360 zmdc[15223].INF [Server shutdown at 11/08/20 22:36:45]
08/20/2011 22:36:46.335226 zmdc[15355].INF [Server starting at 11/08/20 22:36:46]
08/20/2011 22:36:49.440771 zmdc[15355].INF ['zmc -m 1' starting at 11/08/20 22:36:49, pid = 15401]
08/20/2011 22:36:49.545384 zmdc[15355].INF ['zmc -m 2' starting at 11/08/20 22:36:49, pid = 15404]
08/20/2011 22:36:49.648160 zmdc[15355].INF ['zmfilter.pl' starting at 11/08/20 22:36:49, pid = 15407]
08/20/2011 22:36:49.750775 zmdc[15355].INF ['zmaudit.pl -c' starting at 11/08/20 22:36:49, pid = 15410]
08/20/2011 22:36:49.851119 zmdc[15355].INF ['zmwatch.pl' starting at 11/08/20 22:36:49, pid = 15413]
08/20/2011 22:37:51.915954 zmdc[15355].INF ['zmwatch.pl ' stopping at 11/08/20 22:37:51]
08/20/2011 22:37:51.917447 zmdc[15355].INF ['zmwatch.pl ' exited, signal 14]
08/20/2011 22:37:51.917654 zmdc[15355].INF ['zmaudit.pl -c' stopping at 11/08/20 22:37:51]
08/20/2011 22:37:51.918785 zmdc[15355].INF ['zmaudit.pl -c' exited, signal 14]
08/20/2011 22:37:51.918993 zmdc[15355].INF ['zmc -m 2' stopping at 11/08/20 22:37:51]
08/20/2011 22:37:57.926387 zmdc[15355].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:37:57.926681 zmdc[15355].INF ['zmfilter.pl ' stopping at 11/08/20 22:37:57]
08/20/2011 22:37:57.928896 zmdc[15355].INF ['zmfilter.pl ' exited, signal 14]
08/20/2011 22:37:57.929104 zmdc[15355].INF ['zmc -m 1' stopping at 11/08/20 22:37:57]
08/20/2011 22:38:03.944155 zmdc[15355].INF ['zmc -m 1' crashed, signal 8]
08/20/2011 22:38:14.052818 zmdc[15355].INF [Server shutdown at 11/08/20 22:38:14]
08/20/2011 22:38:14.480632 zmdc[15702].INF [Server starting at 11/08/20 22:38:14]
08/20/2011 22:38:17.602003 zmdc[15702].INF ['zmc -m 1' starting at 11/08/20 22:38:17, pid = 15725]
08/20/2011 22:38:17.741732 zmdc[15702].INF ['zmc -m 2' starting at 11/08/20 22:38:17, pid = 15728]
08/20/2011 22:38:17.843899 zmdc[15702].INF ['zmfilter.pl' starting at 11/08/20 22:38:17, pid = 15731]
08/20/2011 22:38:17.944767 zmdc[15702].INF ['zmaudit.pl -c' starting at 11/08/20 22:38:17, pid = 15734]
08/20/2011 22:38:18.066426 zmdc[15702].INF ['zmwatch.pl' starting at 11/08/20 22:38:18, pid = 15737]
08/20/2011 22:39:38.276163 zmdc[15702].INF ['zmc -m 2' stopping at 11/08/20 22:39:38]
08/20/2011 22:39:39.294873 zmdc[15702].ERR ['zmc -m 2' exited abnormally, exit status 11]
08/20/2011 22:39:39.395564 zmdc[15702].INF [Starting pending process, zmc -m 2]
08/20/2011 22:39:39.396432 zmdc[15702].INF ['zmc -m 2' starting at 11/08/20 22:39:39, pid = 15887]
08/20/2011 22:43:49.411020 zmdc[15702].INF ['zmc -m 2' stopping at 11/08/20 22:43:49]
08/20/2011 22:43:55.423837 zmdc[15702].INF ['zmc -m 2' crashed, signal 8]
08/20/2011 22:44:00.033071 zmdc[15702].INF [Starting pending process, zmc -m 2]
08/20/2011 22:44:00.034053 zmdc[15702].INF ['zmc -m 2' starting at 11/08/20 22:44:00, pid = 16345]
zm_debug.log.16345
[rtsp @ 0x74f5b50]video codec set to: h264
[NULL @ 0x74df8f0]RTP Packetization Mode: 1
[NULL @ 0x74df8f0]RTP Profile IDC: 42 Profile IOP: 0 Level: 29
[NULL @ 0x74df8f0]Extradata set to 0x74e7030 (size: 29)!hello state=0
[h264 @ 0x74df8f0]non-existing PPS referenced
Last message repeated 72 times
[rtsp @ 0x74f5b50]All info found
[rtsp @ 0x74f5b50]Estimating duration from bitrate, this may be inaccurate
[swscaler @ 0x7500af0]No accelerated colorspace conversion found from yuv420p to rgb24.
08/20/11 22:44:00.044510 zmc_m2[-1].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.16345]
08/20/11 22:44:00.044647 zmc_m2[-1].DB1-zm_monitor.cpp/2262 [Got 1 monitors]
08/20/11 22:44:00.049445 zmc_m2[-1].DB1-zm_monitor.cpp/338 [monitor purpose=1]
08/20/11 22:44:00.049459 zmc_m2[-1].DB1-zm_monitor.cpp/345 [mem.size=122881524]
08/20/11 22:44:00.082007 zmc_m2[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 1280x800 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:5
0000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
08/20/11 22:44:00.106035 zmc_m2[-1].DB1-zm_monitor.cpp/458 [Monitor Axis-1 has function 2]
08/20/11 22:44:00.106050 zmc_m2[-1].DB1-zm_monitor.cpp/459 [Monitor Axis-1 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
08/20/11 22:44:00.106054 zmc_m2[-1].DB1-zm_monitor.cpp/460 [Monitor Axis-1 IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
08/20/11 22:44:00.106165 zmc_m2[-1].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Axis-1]
08/20/11 22:44:00.106176 zmc_m2[-1].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 1279,0 1279,799 0,799]
08/20/11 22:44:00.106180 zmc_m2[-1].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 1279,0 1279,799 0,799']
08/20/11 22:44:00.106185 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
08/20/11 22:44:00.106188 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 1279,0 from polygon string]
08/20/11 22:44:00.106192 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 1279,799 from polygon string]
08/20/11 22:44:00.106196 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,799 from polygon string]
08/20/11 22:44:00.106205 zmc_m2[-1].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
08/20/11 22:44:00.106211 zmc_m2[-1].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 1280x800 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:30720, MxAP:768000, FB:3x3, MnFP:30720,
MxFP:768000, MnBS:20480, MxBS:0, MnB:1, MxB:0, OF: 0]
08/20/11 22:44:00.130285 zmc_m2[-1].DB1-zm_monitor.cpp/2459 [Loaded monitor 2(Axis-1), 1 zones]
08/20/11 22:44:00.130299 zmc_m2[-1].INF-zmc.cpp/188 [Starting Capture]
08/20/11 22:44:00.130332 zmc_m2[-1].INF-zm_ffmpeg_camera.cpp/80 [Priming capture from rtsp://root:pass@10.0.0.63/axis-media/media.amp]
08/20/11 22:44:11.053310 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.065181 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 0]
08/20/11 22:44:11.065191 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 0]
08/20/11 22:44:11.070271 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.077223 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 1]
08/20/11 22:44:11.077247 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 1]
08/20/11 22:44:11.083065 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.088548 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 2]
08/20/11 22:44:11.088558 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 2]
08/20/11 22:44:11.092239 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.097421 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 3]
08/20/11 22:44:11.097430 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 3]
08/20/11 22:44:11.101110 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.106240 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 4]
08/20/11 22:44:11.106249 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 4]
08/20/11 22:44:11.109953 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.115088 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 5]
08/20/11 22:44:11.115097 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 5]
08/20/11 22:44:11.119121 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.124443 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 6]
08/20/11 22:44:11.124456 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 6]
08/20/11 22:44:11.128345 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.133886 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 7]
08/20/11 22:44:11.133911 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 7]
08/20/11 22:44:11.139792 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.145424 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 8]
08/20/11 22:44:11.145436 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 8]
08/20/11 22:44:11.149086 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.154380 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 9]
08/20/11 22:44:11.154390 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 9]
08/20/11 22:44:11.158067 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.163182 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 10]
08/20/11 22:44:11.163190 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 10]
[[ Many such lines... and then..]]
08/20/11 22:44:11.657907 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 62]
08/20/11 22:44:11.661813 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.667141 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 63]
08/20/11 22:44:11.667151 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 63]
08/20/11 22:44:11.673926 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.681048 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 64]
08/20/11 22:44:11.681059 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 64]
08/20/11 22:44:11.684994 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.690496 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 65]
08/20/11 22:44:11.690506 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 65]
08/20/11 22:44:11.694626 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.699964 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 66]
08/20/11 22:44:11.699974 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 66]
08/20/11 22:4[h264 @ 0x74df8f0]non-existing PPS referenced
Last message repeated 4 times
[h264 @ 0x74df8f0]P sub_mb_type 10 out of range at 2 35
[h264 @ 0x74df8f0]error while decoding MB 2 35
[h264 @ 0x74df8f0]concealing 1247 DC, 1247 AC, 1247 MV errors
Frame num gap 1 13
[h264 @ 0x74df8f0]number of reference frames exceeds max (probably corrupt input), discarding one
Frame num gap 1 14
Frame num gap 1 15
4:11.706479 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.712283 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 67]
08/20/11 22:44:11.712297 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 67]
08/20/11 22:44:11.715992 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.721134 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 68]
08/20/11 22:44:11.721143 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 68]
08/20/11 22:44:11.724840 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.730044 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 69]
08/20/11 22:44:11.730053 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 69]
08/20/11 22:44:11.733754 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.738840 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 70]
08/20/11 22:44:11.738849 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 70]
08/20/11 22:44:11.742557 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:44:11.748238 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 71]
[[And yet more lines.. and then..]]
08/20/11 22:45:02.098131 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 586]
08/20/11 22:45:02.190092 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:45:02.197599 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 587]
08/20/11 22:45:02.197608 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 587]
08/20/11 22:45:02.289252 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:45:02.298222 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 588]
08/20/11 22:45:02.298235 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 588]
08/20/11 22:45:02.371836 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:45:02.379771 zmc_m2[-1].DB3-zm_ffmpeg_camera.cpp/154 [Decoded video packet at frame 589]
08/20/11 22:45:02.379785 zmc_m2[-1].DB1-zm_ffmpeg_camera.cpp/158 [Got frame 589]
08/20/11 22:45:02.468458 zmc_m2[-1].DB5-zm_ffmpeg_camera.cpp/148 [Got packet from stream 0]
08/20/11 22:45:02.474196 zmc_m2[-1].DB3-zm_ff Last message repeated 524 times
[h264 @ 0x74df8f0]missing picture in access unit
Again, I'd love some help. Let me know if more information is needed.
