Page 1 of 1
Event columns
Posted: Tue Aug 23, 2011 9:46 am
by gmar_87
When i click on the events under the "day" column it shows events from the previous day as well as today. Is this a bug of config issue?
The time on the server is correct.
I would like to see events from 00:01 to 23:59 when selecting events under the day column.
Can someone please help?
Re: Event columns
Posted: Tue Aug 23, 2011 9:50 am
by jameswilson
it shows the last 24 hours its not a config issue just the way it works.
Re: Event columns
Posted: Wed Aug 24, 2011 10:27 am
by gmar_87
Thanks man
Re: Event columns
Posted: Thu Aug 25, 2011 3:55 pm
by zoneminder
If you only want the events from 'today' then you can change the filter used in console.php in web/skins/classics/views and use the one from the mobile skin which is just events since midnight.
Re: Event columns
Posted: Mon Aug 29, 2011 7:48 am
by gmar_87
zoneminder wrote:If you only want the events from 'today' then you can change the filter used in console.php in web/skins/classics/views and use the one from the mobile skin which is just events since midnight.
Thanks. I'll give that a go!
