Refresh Rate
tetepppp
Refresh Rate
Post by tetepppp »
I have installed zoneminder under Centos 6 64 bit.
I have a strange issue on the picture.
The picture refresh if I click the picture. I can see the timestamp not moving if I didn;t click it. If I click then the picture is refreshed and the timestamp change.
If I didn't click it, it refreshs in around 20 seconds.
I am opening zoneminder using Windows 7 64 bit and IE 9.
Anyone encounter this issue? Any setting need to be adjusted?
Thanks in advance.
kross
Re: Refresh Rate
Post by kross »
I've had the best luck using Firefox instead of IE or Chrome. I also use the "jpeg" method, as defined under Options->Images on the Zoneminder page.
Hope this helps!
-- Kevin
