Page 1 of 1
Ubuntu 10.04 Desktop install-httpd unrecognized service SOLV
Posted: Tue Aug 30, 2011 3:17 am
by GrayBeardNerd
I used the Wiki "Ubuntu 10.04 (Lucid Lynx) Desktop" install instructions and followed them exactly.
I am running on Ubuntu 10.04 (64 bit) Kernel Linus 2.6.32-33 generic (I also tried 32 bit) clean install followed by updates - AMD Phenom II X6 1055T
When I do the service httpd start, I get "httpd: unrecognized service"
Does this mean that there is something wrong with apache2?
I do a service zoneminder start and I can get the console (localhost/zm)
My camera shows up fine with XawTV
I bring up the ZoneMinder Console - Running - v1.24.2
I've created a single local monitor with defaults including /dev/vedeo (0) and NTSC
On the ZM Console, I clink on Monitor-1 and get the window, but it always says, "Waiting for localhost..."
During the install when it said Starting web server apache2,
apache2: Could not reliably determine the server's fully qualified domain name, using 127 0 1 1 for ServerName.
No crash messages from apache2.
My /etc/apache2/httpd.conf file is empty.
If I search the forum with "+httpd +unrecognized +service" I get one match with someone with a Fedora issue and a response to install apache2.
Google gives a bewildering variety of answers to the missing service. Apache org only has one hit on the search.
This is the fourth time I've formatted the disc and started the install. I don't understand what I am doing different from the Wiki instructions.
Re: Ubuntu 10.04 Desktop install - httpd unrecognized servi
Posted: Tue Aug 30, 2011 10:58 am
by bb99
I'm going to suggest that your "hosts" file does not have a localhost entry. You can edit it or try http//:127.0.1.1/zm (usually 127.0.0.1, not sure why the 127.0.1.1) and see if that gets you to the main page.
Posted: Tue Aug 30, 2011 6:04 pm
by GrayBeardNerd
Thanks for the info bb99.
I looked at my /etc/hosts file and it has
127.0.0.1 localhost
127.0.1.1 zzz-desktop
and IPv6 stuff
When I try 127.0.1.1/zm in my Firefox, I get the same console that I get with localhost
and if I click on Monitor-1 in the Name column, I get the same window with "Waiting for 127.0.1.1..."
On previous attempts, I tried to uninstall apache2, then reinstalled it, and that just made a mess.
It is a local camera that goes to a Black Cherry PV-149PA board and I am trying to view it on the PC with the Black Cherry board. The ZoneMinder console appears to work, except viewing the monitor. This is my first time trying to use ZoneMinder, so I don't know what is expected behavior.
Posted: Tue Aug 30, 2011 10:51 pm
by bb99
Check to see if the "'deny from all' delete this line" entry has been removed from /etc/httpd/conf.d/zoneminder.conf; just a guess here...
Posted: Wed Aug 31, 2011 2:16 am
by GrayBeardNerd
Good catch bb99.
The /etc/apache2/conf.d/zoneminder.conf link was misnamed zoneinder.conf. I corrected that with a new ln command and there is no change in symptoms. I didn't find an httpd folder in /etc.
I had also changed /etc/apache2/httpd.conf and /etc/hosts, and that made the "Could not determine the server's fully qualified domain name" message go away.
The two symptoms remaining are: the command service httpd start gives unrecognized service and in the ZoneMinder Console window, clicking on the Monitor-1 link opens the Monitor-1 window and shows the controls, but no video and the status line shows "Waiting for localhost..."
The file is from the /var/log/apache2/error.log
Posted: Wed Aug 31, 2011 10:56 am
by bb99
Posted: Thu Sep 01, 2011 3:54 am
by bb99
Continued from: http://www.zoneminder.com/forums/viewto ... 21&t=17807
Most of this forum is best guess, some good, some not so good. I'm guessing (reads like) we're down to a palette choice; Try BGR24, post back.
Posted: Thu Sep 01, 2011 4:10 am
by GrayBeardNerd
Oh, that's just amazing bb99!
I now have video. TYSM!
To recap for the thread,
edited the hosts file
delay the startup of zoneminder for a race condition
ensure that device matches exactly
changed from RGB24 to BGR24
Posted: Thu Sep 01, 2011 4:15 am
by bb99
Perfect! Enjoy ZM it's really very good. Keep in mind that to increase your resolution you will need to pay attention to how much shared memory you've allocated.... Please edit the title to "solved", makes others searching the forum very easy to select a winner.
