Problems changing resolution
Posted: Wed Aug 31, 2011 2:53 pm
I have some IPcam FOSCAM FI8918W and FI8905W.
I've got installed ZM in traditional mode (with "Package manger" I think - in italian is "Gestore pacchetti") and I install correctly all the IPcam in ZM.
I found some problems when I change the resolution of my IPcam from its URL: for example I change it from 320x240 in 640x480 but writing in the source/source both 320x240 and 640x480 I can't view anything.
With another computer on which I installed ZM with the following script I haven't that problem. In particular the various situation I notice are indicated below the script...
These are the situation I notify:
With traditional intallation:
IPcam......Source/source....Source color....Streaming........Event
320x240...320x240.............green..............OK..................OK
320x240...640x480.............red.................none................none
640x480...320x240.............red.................black screen.....OK
640x480...640x480.............red.................none................none
With script:
320x240...640x480.............red.................black screen.....OK (with resolution 320x240 but dimension 640x480)
640x480...640x480.............green.............OK...................OK (with resolution 320x240 but dimension 640x480)
I don't know if the different behavior is caused by the script but I think that the only one difference in the installation is that.
Any idea to solve that problem???
Thank you
pp1981
#!/bin/sh
# ZoneMinder 1.24.2 installation script
# Copyright (C) 2010 Chris "Pada" Kistner
echo "--- Checking for root privileges..."
if [ "`whoami`" != "root" ]; then
echo Error: This script requires root access
exit 1
fi
echo "--- Installing extra codecs, which includes x264 support..."
apt-get -y install libavcodec-extra-52 libavformat-extra-52 libswscale-extra-0 libavfilter-extra-1
echo "--- Installing ZoneMinder..."
apt-get -y install zoneminder
echo "--- Adding ZoneMinder to Apache2..."
ln -s /etc/zm/apache.conf /etc/apache2/sites-available/zoneminder.conf
a2ensite zoneminder
service apache2 restart
echo "--- Adding alias for zoneminder service and fixing ZoneMinder startup..."
ln -s /etc/init.d/zoneminder /etc/init.d/zm
update-rc.d -f zoneminder remove
update-rc.d -f zm remove
update-rc.d zm defaults 92
echo "--- Applying ZMFix, adding www-data user to video group and restarting ZM..."
chmod 4755 /usr/bin/zmfix
zmfix -a
adduser www-data video
service zm restart
echo "--- Correcting SHM to 90% of memory..."
apt-get -y install coreutils bc
page_size=$(getconf PAGE_SIZE)
mem_bytes=$(awk '/MemTotal:/ { printf "%0.f",$2 * 1024}' /proc/meminfo)
mb=1048576
mem_bytes_mb=$(expr $mem_bytes / $mb)
shmmax=$(echo "$mem_bytes * 0.90" | bc | cut -f 1 -d '.')
shmmax_mb=$(expr $shmmax / $mb)
shmall=$(expr $mem_bytes / $page_size)
shmmax_cur=$(sysctl -n kernel.shmmax)
shmmax_cur_mb=$(expr $shmmax_cur / $mb)
shmall_cur=$(sysctl -n kernel.shmall)
echo "-- Total memory = $mem_bytes B = $mem_bytes_mb MB"
echo "-- Page size = $page_size B"
echo "-- Current kernel.shmmax = $shmmax_cur B = $shmmax_cur_mb MB"
echo "-- Current kernel.shmall = $shmall_cur pages"
if [ "$shmmax" -eq "$shmmax_cur" ] && [ "$shmall" -eq "$shmall_cur" ]; then
echo "-- Recommended shm values already set"
else
echo "-- Recommended: kernel.shmmax = $shmmax B = $shmmax_mb MB"
echo "-- Recommended: kernel.shmmall = $shmall pages"
file=/etc/sysctl.conf
if [ "`grep "^kernel\.shmmax" $file -c`" != "0" ]; then
echo "-- Replacing: kernel.shmmax in $file"
sed "s/^kernel\.shmmax.*$/kernel.shmmax=$shmmax/g" -i $file
else
echo "-- Adding: kernel.shmmax to $file"
echo kernel.shmmax=$shmmax >> $file
fi
if [ "`grep "^kernel\.shmall" /etc/sysctl.conf -c`" != "0" ]; then
echo "-- Replacing: kernel.shmall in $file"
sed "s/^kernel\.shmall.*$/kernel.shmall=$shmall/g" -i $file
else
echo "-- Adding: kernel.shmall to $file"
echo kernel.shmall=$shmall >> $file
fi
echo "-- Using: new sysctl values"
sysctl -p
fi
# Done
echo "--- Done."
With script:
Thank you
pp1981
