poblemsafter latest debian update (probably ffmpeg or s.th.)
event
Post by event »
I'm running zoneminde 1.24.2 on a debian squeeze box. Besides other things mainly to provide a webserver where i can watch 4 webcams at the same time, using the "montage" feature.
I'm using 4 allnet 2290, grabbing the mpeg4 stream over rtsp.
It was working more than fine for over a year, but since I did a regular aptitude update / aptitude upgrade now suddenly the pictures get blury all the time and the stream stops and stuff like that.
If i restart zoneminder its running fine for a few seconds before going bad again.
Anybody got any idea what i can do now?
event
Re: poblemsafter latest debian update (probably ffmpeg or s.
Post by event »
seems like i got it working again by deupdating the ffmpeg package (using aptitude, had to deupgrade some other packages to to make it work).
i 4:0.5.2-6
p 5:0.6.1+svn20101128-0.2
0.6.1 caused trouble for me, have to pin version 0.5.2 for now.
btw, iam running debian squeeze, 2.6.32-5-xen-amd64
bb99
Post by bb99 »
What other packages did you have to "deupgrade"?
event
Post by event »
I told aptitude to install the older ffmpeg version. Then it told me there where dependencies not resolved. So i checked the suggestions, the 3rd one offered 3 downgrades besides ffmpeg, so i did that one. It also removed some other packages, which apparently where installed as dependencies to one of packages newer version.
I copied to important parts from my dpkg.log:
2011-09-03 21:37:36 upgrade ffmpeg 5:0.6.1+svn20101128-0.2 4:0.5.2-6
2011-09-03 21:37:36 upgrade libavdevice52 5:0.6.1+svn20101128-0.2 4:0.5.2-6
2011-09-03 21:37:36 upgrade libavformat52 5:0.6.1+svn20101128-0.2 4:0.5.2-6
2011-09-03 21:37:37 upgrade libavcodec52 5:0.6.1+svn20101128-0.2 4:0.5.2-6
2011-09-03 21:37:39 remove libfaac0 1.28-0.3 1.28-0.3
2011-09-03 21:37:40 remove libmp3lame0 3.98.4-0.0 3.98.4-0.0
2011-09-03 21:37:40 remove librtmp0 2.3-2 2.3-2
2011-09-03 21:37:40 remove libx264-112 1:0.svn20110115-0.0 1:0.svn20110115-0.0
2011-09-03 21:37:40 remove libxvidcore4 2:1.2.2-0.1 2:1.2.2-0.1
2011-09-03 21:37:40 remove libva-x11-1 1.0.7-0.0 1.0.7-0.0
