clouds causing recording & length recording like min 1min
Schuhkasten
Post by Schuhkasten »
Hello
actually I have big problem clouds. Is there a way so sort it out? I try to set min/max ranges Alarmed Area but maybe wrong approach?
Concerning the recording lenght is it possible to let record for at least a defined time like 60 seconds or similar?
THX
bb99
Re: clouds causing recording & length recording like min 1mi
Post by bb99 »
Try changing (increases) the "Overload Frame Ignore Count" in zone settings, increase "Reference Image Blend %ge" on monitor:: general tab, and/or increase the "Alarm Frame Count" on the monitor buffers tab. Playing with these settings should get you where you want to be.
Schuhkasten
ok thanks I will try...
I also found that for clouds I can define Preclusive zones, that prohibits a event if it is also triggered in that preclusive zone. Will also try that and report.
Concerning the recording length I thing this can only be set in Mocord mode or if I set the "post event image count" frames to a high number. as Iam actually running at 1FPS it should be no problem to use something like 60 as post event image count.
Goal is not to have 10 short reordering when the postman arrives...
bb99
Post by bb99 »
You nailed it! Was thinking you were trying to reduce to 60 sec. but raising the post buffer will combine many short consecutive events into one larger event.
