Zoneminder Video Capture Card
jriavec
Post by jriavec »
Hello Everybody, I've been using for over the past 3 years the Video Capture Card PV-981A1-16 with 12 Cameras running on it.
I bought it from Bluecherry, but now I'm looking something more sophisticated that will work with ZoneMinder v1.24.1.
Does Anyone knows and had experience with other hardware compatible with ZM?
I will appreciate your help.
Regards
Julian
mastertheknife
Re: Zoneminder Video Capture Card
Post by mastertheknife »
That card should be compatible with ZM. What error do you receive when trying it with a recent ZM version?
mastertheknife
Kfir Itzhak.
jriavec
Post by jriavec »
Hi Kfir, thanks for your quick response, it is not that is not working, I just want to change it or look for another hardware. It is working OK, but I will split the Zoneminder in two, having another ZM installed in another server and I wanted to know if there is any better Video Card compatible with ZM. Just to have more options
Kind Regards
Julian
