I want to know how and where I must edit the entry for the socket entry, because i use the lampp distribution with the included mysql server.
Update:
When i start "rczm start"
the screen shows:
Starting ZoneMinder Daemon DBI connect('database=zm;host=localhost','zm_admin',...) failed: Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2) at /usr/lib/perl5/vendor_perl/5.12.3/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/lib/perl5/vendor_perl/5.12.3/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.12.3/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/lib/perl5/vendor_perl/5.12.3/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.12.3/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 37.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 37.
what must i do?
Thanks a lot.
Michael
