[Solved] Recordings doesn't stop
Hi all,
I'm using zm 1.24.2-8ubuntu1 in 11.04-64bit with IN-2905.
With alarm-problems under conditions clouds, sun and wind I have created six zones with "Best, medium sensitivity".
I changed settings "Overload Frame Ignore Count" to 4, "Reference Image Blend %ge" to 9, "Pre Event Image Count" to 21, "Post Event Image Count" to 50.
Now the alarm with record starts as I wish. But the record stop to late. The alarm-action goes 30 secs, but the record stop at 1200 secs.
What setting I should change, that the record will stop 15 sec after the end of the action for alarm ?
Thanks in advance
Regards Michael
Thanks in advance
Regards Michael
Re: Recordings doesn't stop
I changed "Pre Event Image Count" back to 10 and "Post Event Image Count" back to 10. I'm thinking this is the default value.
The alarm-settings with record-start is now perfekt, but the record is runing without an end and the disk become full.
Any hints.
Regards Michael
Any hints.
Regards Michael
Change all your settings back to default one by one, restarting ZM after each change until symptom disappears. As a thought: we're talking only one camera here right? otherwise you may have linked monitors causing a perpetual alarm.
Hi bb99,
it's only one IN-2905 via WLAN.
I changed many times step by step to default setting during the last days.
Now I have settings, which are optimal for starting a record by alarm. There are no problems with clouds, sun or wind.
But the record doesn't stop ... but the current record stop at the next alarm. Then starts the next record without an end until the next alarm.
Thanks and regards
Michael
Thanks and regards
Michael
Example: I cleared all events, restart zm, went outside late night with our dog (record is starting, but don't stop), returned (first record stop, but the second record doesn't stop til I made in following early morning the next run with our dog.
Thanks Michael
Thanks Michael
Sep 22 13:56:43 RumiNN64 zmdc[2943]: INF [Server shutdown at 11/09/22 13:56:43]
Sep 22 13:56:44 RumiNN64 zmdc[3312]: INF [Server starting at 11/09/22 13:56:44]
Sep 22 13:56:47 RumiNN64 zmdc[3312]: INF ['zmc -m 2' starting at 11/09/22 13:56:47, pid = 3334]
Sep 22 13:56:47 RumiNN64 zmdc[3334]: INF ['zmc -m 2' started at 11/09/22 13:56:47]
Sep 22 13:56:47 RumiNN64 zmc_m2[3334]: INF [Debug Level = 0, Debug Log = <none>]
Sep 22 13:56:47 RumiNN64 zmdc[3312]: INF ['zma -m 2' starting at 11/09/22 13:56:47, pid = 3336]
Sep 22 13:56:47 RumiNN64 zmdc[3336]: INF ['zma -m 2' started at 11/09/22 13:56:47]
Sep 22 13:56:47 RumiNN64 zma_m2[3336]: INF [Debug Level = 0, Debug Log = <none>]
Sep 22 13:56:47 RumiNN64 zmc_m2[3334]: INF [Starting Capture]
Sep 22 13:56:47 RumiNN64 zma_m2[3336]: WAR [Waiting for capture daemon]
Sep 22 13:56:47 RumiNN64 zmdc[3312]: INF ['zmfilter.pl' starting at 11/09/22 13:56:47, pid = 3338]
Sep 22 13:56:47 RumiNN64 zmdc[3338]: INF ['zmfilter.pl' started at 11/09/22 13:56:47]
Sep 22 13:56:47 RumiNN64 zmdc[3312]: INF ['zmaudit.pl -c' starting at 11/09/22 13:56:47, pid = 3340
Sep 22 13:56:47 RumiNN64 zmdc[3340]: INF ['zmaudit.pl -c' started at 11/09/22 13:56:47]
Sep 22 13:56:47 RumiNN64 zmfilter[3338]: INF [Scanning for events]
Sep 22 13:56:47 RumiNN64 zmdc[3312]: INF ['zmwatch.pl' starting at 11/09/22 13:56:47, pid = 3342]
Sep 22 13:56:48 RumiNN64 zmdc[3342]: INF ['zmwatch.pl' started at 11/09/22 13:56:48]
Sep 22 13:56:48 RumiNN64 zmdc[3312]: INF ['zmupdate.pl -c' starting at 11/09/22 13:56:48, pid = 334
4]
Sep 22 13:56:48 RumiNN64 zmdc[3344]: INF ['zmupdate.pl -c' started at 11/09/22 13:56:48]
Sep 22 13:56:48 RumiNN64 zmwatch[3342]: INF [Watchdog starting]
Sep 22 13:56:48 RumiNN64 zmwatch[3342]: INF [Watchdog pausing for 30 seconds]
Sep 22 13:56:48 RumiNN64 zmupdate[3344]: INF [Checking for updates]
Sep 22 13:56:48 RumiNN64 zma_m2[3336]: INF [In mode 3/1, warming up]
Sep 22 13:56:49 RumiNN64 zmupdate[3344]: ERR [Error check failed: '404 Not Found']
Sep 22 13:58:47 RumiNN64 zmc_m2[3334]: INF [LexWebCam: 1000 - Capturing at 8.33 fps]
Sep 22 13:58:47 RumiNN64 zma_m2[3336]: INF [LexWebCam: 1000 - Processing at 8.33 fps]
Any hints ?
Regards Michael
Sorry but I have to ask: The monitor function is set to Modect or Mocord?
I was able to duplicate your problem, I think. If I lowered the reference blend too low for the environment and the alert/alarm frame rate varied at all, the recording would continue until I stopped it manually. I couldn't stop the recording by creating another alarm as you describe though. Anyway try gradually increase the monitor reference blend until it works. I went from a value of 2 (continuous record) to a value of 25 and then backed it down to the best performance (original value +3). Worth a try.
Hello bj99,
sorry about this late answer. I was very busy with other work the last days.
First: Modect
Second: After changing the reference blend (original 7) +3 to 10, the record doesn't stop til now.
Now I could change the value up to 25 and down to 2 ... but record doesn't stop with any value.
The alarm is working fine, but something must be wrong in my configuration.
Thanks in advance.
Regards Michael
First: Modect
Thanks in advance.
Regards Michael
Leave your Reference Image Blend %ge setting at 10 and check your zone settings against these:
- Zone.png (19.86 KiB) Viewed 7354 times
I reduced the 6 zones to 3 and configured the zone-parameter as before posted.
That doesn't help ... now the recordings (after perfect alarm) don't stop anyway.
Regards Michael
Regards Michael
@bj99
please have a look on my three zones with your parameters.
Thanks in advance
Regrads Michael
Thanks in advance
Regrads Michael
- zones_092911_1045.jpeg (161.22 KiB) Viewed 7344 times
This is the syslog-sequence after restart via web-gui ... I went outside generating an alarm.
I'm thinking that the first entries about "monitor 2" ??? generate my general problem of "don't stopping recording".
Any hints ?
Reards Michael
EDIT: After a new restart I saw, that at "Sep 29 14:06:39" the postman was going through one alarm-zone.
Sep 29 14:03:58 RumiNN64 zmpkg[2568]: INF [Command: restart]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmc -m 2' stopping at 11/09/29 14:03:58]
Sep 29 14:03:58 RumiNN64 zmc_m2[2456]: INF [Got signal 15 (Terminated), exiting]
Sep 29 14:03:58 RumiNN64 zmc_m2[2456]: ERR [Select error: Interrupted system call]
Sep 29 14:03:58 RumiNN64 zmc_m2[2456]: ERR [Unable to read content]
Sep 29 14:03:58 RumiNN64 zmc_m2[2456]: ERR [Unable to get response]
Sep 29 14:03:58 RumiNN64 zmc_m2[2456]: ERR [Failed to capture image from monitor 2 (0/1)]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zma -m 2' stopping at 11/09/29 14:03:58]
Sep 29 14:03:58 RumiNN64 zma_m2[2458]: INF [Got signal 15 (Terminated), exiting]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zma -m 2' exited normally]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmwatch.pl ' stopping at 11/09/29 14:03:58]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmwatch.pl ' exited, signal 14]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmaudit.pl -c' stopping at 11/09/29 14:03:58]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmaudit.pl -c' exited, signal 14]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmfilter.pl ' stopping at 11/09/29 14:03:58]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmfilter.pl ' exited, signal 14]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmupdate.pl -c' stopping at 11/09/29 14:03:58]
Sep 29 14:03:58 RumiNN64 zmdc[2434]: INF ['zmupdate.pl -c' exited, signal 14]
Sep 29 14:04:08 RumiNN64 zmdc[2434]: INF [Server shutdown at 11/09/29 14:04:08]
Sep 29 14:04:08 RumiNN64 zmdc[2602]: INF [Server starting at 11/09/29 14:04:08]
Sep 29 14:04:12 RumiNN64 zmdc[2602]: INF ['zmc -m 2' starting at 11/09/29 14:04:12, pid = 2624]
Sep 29 14:04:12 RumiNN64 zmdc[2624]: INF ['zmc -m 2' started at 11/09/29 14:04:12]
Sep 29 14:04:12 RumiNN64 zmc_m2[2624]: INF [Debug Level = 0, Debug Log = <none>]
Sep 29 14:04:12 RumiNN64 zmc_m2[2624]: INF [Starting Capture]
Sep 29 14:04:12 RumiNN64 zmdc[2602]: INF ['zma -m 2' starting at 11/09/29 14:04:12, pid = 2626]
Sep 29 14:04:12 RumiNN64 zmdc[2626]: INF ['zma -m 2' started at 11/09/29 14:04:12]
Sep 29 14:04:12 RumiNN64 zma_m2[2626]: INF [Debug Level = 0, Debug Log = <none>]
Sep 29 14:04:12 RumiNN64 zma_m2[2626]: WAR [Waiting for capture daemon]
Sep 29 14:04:12 RumiNN64 zmdc[2602]: INF ['zmfilter.pl' starting at 11/09/29 14:04:12, pid = 2628]
Sep 29 14:04:12 RumiNN64 zmdc[2628]: INF ['zmfilter.pl' started at 11/09/29 14:04:12]
Sep 29 14:04:12 RumiNN64 zmdc[2602]: INF ['zmaudit.pl -c' starting at 11/09/29 14:04:12, pid = 2630]
Sep 29 14:04:12 RumiNN64 zmdc[2630]: INF ['zmaudit.pl -c' started at 11/09/29 14:04:12]
Sep 29 14:04:12 RumiNN64 zmfilter[2628]: INF [Scanning for events]
Sep 29 14:04:12 RumiNN64 zmdc[2602]: INF ['zmwatch.pl' starting at 11/09/29 14:04:12, pid = 2632]
Sep 29 14:04:12 RumiNN64 zmdc[2632]: INF ['zmwatch.pl' started at 11/09/29 14:04:12]
Sep 29 14:04:12 RumiNN64 zmaudit[2630]: INF [Found orphaned frame records for event '764']
Sep 29 14:04:12 RumiNN64 zmaudit[2630]: INF [deleting]
Sep 29 14:04:12 RumiNN64 zmaudit[2630]: INF [Found orphaned statistic records for event '764']
Sep 29 14:04:12 RumiNN64 zmwatch[2632]: INF [Watchdog starting]
Sep 29 14:04:12 RumiNN64 zmwatch[2632]: INF [Watchdog pausing for 30 seconds]
Sep 29 14:04:12 RumiNN64 zmdc[2602]: INF ['zmupdate.pl -c' starting at 11/09/29 14:04:12, pid = 2634]
Sep 29 14:04:12 RumiNN64 zmdc[2634]: INF ['zmupdate.pl -c' started at 11/09/29 14:04:12]
Sep 29 14:04:13 RumiNN64 zma_m2[2626]: INF [In mode 3/1, warming up]
Sep 29 14:04:13 RumiNN64 zmupdate[2634]: INF [Checking for updates]
Sep 29 14:04:13 RumiNN64 zmupdate[2634]: ERR [Error check failed: '404 Not Found']
Sep 29 14:05:49 RumiNN64 zmc_m2[2624]: INF [LexWebCam: 1000 - Capturing at 10.31 fps]
Sep 29 14:05:50 RumiNN64 zma_m2[2626]: INF [LexWebCam: 1000 - Processing at 10.20 fps]
Sep 29 14:06:39 RumiNN64 zma_m2[2626]: INF [LexWebCam: 1494 - Gone into prealarm state]
Sep 29 14:06:39 RumiNN64 zma_m2[2626]: INF [LexWebCam: 1496 - Gone into prealarm state]
Sep 29 14:06:40 RumiNN64 zma_m2[2626]: INF [LexWebCam: 1498 - Gone into prealarm state]
Sep 29 14:06:40 RumiNN64 zma_m2[2626]: INF [LexWebCam: 1501 - Gone into alarm state]
Sep 29 14:06:40 RumiNN64 zma_m2[2626]: INF [LexWebCam: 1501 - Opening new event 765, alarm start]
Sep 29 14:07:30 RumiNN64 zmc_m2[2624]: INF [LexWebCam: 2000 - Capturing at 9.90 fps]
Sep 29 14:07:31 RumiNN64 zma_m2[2626]: INF [LexWebCam: 2000 - Processing at 9.90 fps]
Sep 29 14:09:01 RumiNN64 CRON[2668]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -cmin +$(/usr/lib/php5/maxlifetime) -delete)
Sep 29 14:09:07 RumiNN64 zmc_m2[2624]: INF [LexWebCam: 3000 - Capturing at 10.31 fps]
Sep 29 14:09:07 RumiNN64 zma_m2[2626]: INF [LexWebCam: 3000 - Processing at 10.42 fps]
Sep 29 14:10:38 RumiNN64 zmc_m2[2624]: INF [LexWebCam: 4000 - Capturing at 10.99 fps]
Sep 29 14:10:38 RumiNN64 zma_m2[2626]: INF [LexWebCam: 4000 - Processing at 10.99 fps]
Sep 29 14:12:08 RumiNN64 zmc_m2[2624]: INF [LexWebCam: 5000 - Capturing at 11.11 fps]
Sep 29 14:12:09 RumiNN64 zma_m2[2626]: INF [LexWebCam: 5000 - Processing at 10.99 fps]
Any hints ?
Reards Michael
Hi all,
my problem isn't solved till now.
I reduced it to one zone with the settings above.
The alarm and the recording start perfectly ... but now the record of an event never stop.
Any other hints ? Thanks in advance.
Regards Michael
Regards Michael
One zone? One camera?
