1. Error reporting about gettimeofday whining about not being safe to rely on system timezone.
Unknown error type: [2] gettimeofday(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still gett
2. I no longer see the 'still' images, I can still see the motion, just not the individual frames. I notice if I click the 'slider' on the stills window, I see the error from point 1, each time.
I am using Gentoo amd64 ebuild from layman overlay zugaina.
I have run zmupdate -f , everything but the stills display, seems to be ok.
Suggestions welcomed
