Page 1 of 1
(Solved) Cannot connect to ZM desktop from another pc
Posted: Mon Sep 26, 2011 6:38 pm
by camsystem
I have successfully set up ZM 1.24.2 on a Ubuntu 10.04 desktop. When ever I try to access ZM from a different PC on the local network (put the IP address on the browser), I get this message:
"It works!
This is the default web page for this server.
The web server software is running but no content has been added, yet."
I tried to set up new users per Wiki link: http://www.zoneminder.com/wiki/index.ph ... ZoneMinder
There is no users tab in the options menu.
Any help or directions or web links would be greatly appreciated.
Re: Cannot connect to ZM desktop from another pc
Posted: Mon Sep 26, 2011 7:16 pm
by camsystem
Keep on researching and found that I needed to enable Option -> System -> OPT_USE_AUTH before the user tab will appear. Tried to restart ZM but it now wants to to enter a login ID and password. I have tried root, admin, name of server and various password to no avail. Yikes! How do I logon as admin?
Any help will be appreciated!
Posted: Mon Sep 26, 2011 7:37 pm
by nightcrawler
did you use /zm/ in your url? else you will enter the "root" of your apache webserver and you will get the default message" IT WORKS".
so use: http://yourdomain.com/zm/index.php or http://youriphere/zm/index.php
and admin logon is: admin/admin (nice short graphical manual : http://kotisivu.dnainternet.net/vuorris ... index.html)
Posted: Tue Sep 27, 2011 6:14 pm
by camsystem
It works. Thanks for the assistence
Posted: Tue Sep 27, 2011 6:34 pm
by camsystem
I would like to solve this thread. What would be the proper address if connecting from an external PC? I have a router and my local IP's are 192.168.xxx.xxx
Posted: Tue Sep 27, 2011 8:03 pm
by PacoLM
You have to use a DDNS provider (www,dyndns.com, for instance), if your internet provider has dynamic ip assignment. The ip 192.168.x.x is the internal IP,not the external. You have to subscribe to a DDNS server that will provide an alias (like mysystem.getmyip.com), where you could connect from a external net. To do this you will need to modify your router settings also.
If your provider assigns a fixed ip to your router, then is easier, you only have to write down your public ip and that's all.
Hope it helps,
PacoLM
Posted: Wed Sep 28, 2011 1:17 am
by camsystem
Thanks for the response. If I use the external IP address to Internet, I will not need DNS name services. Short of sticking the computer with ZM in the DMZ zone, what ports would I need to open up on my router?
Posted: Wed Sep 28, 2011 10:36 am
by PacoLM
The port that is using apache2, usually 80. You should open it in your router.
Posted: Fri Sep 30, 2011 3:11 pm
by PacoLM
Any advance?
Posted: Mon Oct 03, 2011 3:44 pm
by camsystem
Turns out my ISP's network is using an RFC1918 IP address. More info located here: http://www.dyndnscommunity.com/question ... e-net.html
I will not be able to connect to my home network from an external IP unless i purchase a static IP.
Much thanks for the help and advise. Solving out this thread as I can now connect from a different PC that is on my home network.
