Anyone test this camera ? or suggestion for a outdoor ir cam
kerlo
Post by kerlo »
Before buy it i want to know
http://www.dealextreme.com/p/ip-wireles ... sion-29918
or if you have any other proposition ..
PacoLM
Re: Anyone test this camera ? or suggestion for a outdoor ir
Post by PacoLM »
I have two of them, working outdoors 24x7 since more than one year, no problems if the wifi signal is good enough. I had to change the lenses, becuase I wanted more area to be covered.
Regards,
PacoLM
kerlo
Post by kerlo »
Many thanks for your answer
what setup are you using
i order one
PacoLM
Post by PacoLM »
Guruplug server plus with Debian Wheezy booting from e-sata disk, 2 of these cams +`another dealextreme, running modect 24x7 and sending email when the video has a certain lenght.
Works like a charm from my point of view, small, not expensive and eats only 5W!
Regards,
PacoLM
dynaguy
Post by dynaguy »
I am also interested on this. Do you know if it works with POE? I mean I run a Cat6 cable to it with POE switch on the other end.
Thanks.
