Page 1 of 1
Anyone test this camera ? or suggestion for a outdoor ir cam
Posted: Tue Sep 27, 2011 10:14 am
by kerlo
Before buy it i want to know
http://www.dealextreme.com/p/ip-wireles ... sion-29918
or if you have any other proposition ..
Re: Anyone test this camera ? or suggestion for a outdoor ir
Posted: Tue Sep 27, 2011 7:58 pm
by PacoLM
I have two of them, working outdoors 24x7 since more than one year, no problems if the wifi signal is good enough. I had to change the lenses, becuase I wanted more area to be covered.
Regards,
PacoLM
Posted: Tue Sep 27, 2011 9:21 pm
by kerlo
Many thanks for your answer
what setup are you using
i order one
Posted: Wed Sep 28, 2011 6:25 pm
by PacoLM
Guruplug server plus with Debian Wheezy booting from e-sata disk, 2 of these cams +`another dealextreme, running modect 24x7 and sending email when the video has a certain lenght.
Works like a charm from my point of view, small, not expensive and eats only 5W!
Regards,
PacoLM
Posted: Fri Nov 04, 2011 6:59 pm
by dynaguy
I am also interested on this. Do you know if it works with POE? I mean I run a Cat6 cable to it with POE switch on the other end.
Thanks.
