Page 1 of 1
PurgeWhenFull Filter Missing
Posted: Wed Sep 28, 2011 3:08 pm
by petecarr90
Installed a fresh ZM 1.25 on Ubuntu 11.04 under MS-HyperV, hooked up 7 IP cameras all working perfectly. However I can't find the PurgeWhenFull filter that I have in my v1.24 installation. Does 1.25 automatically purge and I don't need to worry about the disk filling up?
Thanks Peter
Re: PurgeWhenFull Filter Missing
Posted: Thu Sep 29, 2011 3:44 pm
by MJN
It was in my install (albeit not enabled for background running, and it was a compilation from source).
You can just recreate your own with the following default parameters:
Archive Status equal to Unarchived Only
and Disk Percent greater than or equal to 95
Limit to first 5 results only
Delete all matches
(and set it to run in the background when saving it)
Mathew
