Page 1 of 1
No email/message sent
Posted: Fri Sep 30, 2011 5:02 pm
by magicloud
Recently, I got no email on alert. Checking the log, I saw "Creating notification email". But no "Sending notification message" and "Notification message sent".
What's wrong? I did not see zmfilter.pl exited abnormally or such kind of thing in zmdc.log.
Re: No email/message sent
Posted: Thu Nov 17, 2011 11:01 pm
by leeroybrown
Have you got mail sent yet ? I too am having trouble with email.
Posted: Tue Nov 22, 2011 5:35 pm
by zz11z1
i can send email. First,i setup in email options ,second i setup filter. Do you setup your email?
Posted: Sat Nov 26, 2011 5:16 pm
by leeroybrown
I have set it up yes, smtp.broadband.rogers.com, I need to connect on port 587 and I see it trying to connect on port 25 in my firewall but I check the email and there is nothing there. I have foscams and they work but there is a spot to specify port and authentication credentials. I need to edit the config file to use port 587, I cannot find the file to edit, do you know if there is added email features in teh 1.25 release ? I will reinstall or even change OS if it will help, Ubuntu 10.04.
Posted: Sat Dec 03, 2011 10:34 pm
by PacoLM
Have you installed postfix and configured it?
Posted: Tue Dec 06, 2011 3:24 pm
by leeroybrown
I have played with postfix yes, I was going to ask if it was needed. I have postfix running but I will have to play with it some more. Or I will have to settle for FTP. Thanks.
