Don't poll cameras that are not enabled
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
I have a couple of wireless IP cameras I occasionally turn on to watch pet activity within the house. It can be pretty amusing sometimes.
When I have the cameras turned off, I un-check the "Enabled" check box under the appropriate monitor. However, Zoneminder 1.25.0 continues to check for the presence of these cameras and fills the log with errors:
2011-10-04 07:52:17.579210	zmdc	15811	ERR	'zmc -m 1' exited abnormally, exit status 255	zmdc.pl
2011-10-04 07:52:17.577830	zmdc	15811	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2011-10-04 07:52:17.516020	zmc_m1	19574	ERR	Failed to pre-capture monitor 1 (0/1)	zmc.cpp	256
2011-10-04 07:52:17.515912	zmc_m1	19574	ERR	Unable to connect to camera	zm_remote_camera_http.cpp	1069
2011-10-04 07:52:17.515451	zmc_m1	19574	ERR	Can't connect to remote camera: No route to host	zm_remote_camera_http.cpp	101
2011-10-04 07:52:17.511454	zmc_m3	19573	ERR	Failed to pre-capture monitor 3 (0/1)	zmc.cpp	256
2011-10-04 07:52:17.511188	zmc_m3	19573	ERR	Unable to connect to camera	zm_remote_camera_http.cpp	1069
2011-10-04 07:52:17.510548	zmc_m3	19573	ERR	Can't connect to remote camera: No route to host	zm_remote_camera_http.cpp	101
As far as I know, I'm doing everything right here so I am logging this as a feature request.
When a camera is not enabled, Zoneminder should not poll the device.
PowerRanger
Re: Don't poll cameras that are not enabled
Post by PowerRanger »
As a possible workaround, have you tried setting 'Function' to none?
Sorry for the late reply.
I can confirm that setting the function to "none" stops the error log from filling up.
