good morning,
excuse my poor english, some days I'm testing with zoneminder Foscam cam and with good results, but I do not see a function that I need for work, scheduling the recording cameras.
Perhaps I could not find this function as the program is very broad, someone can help me?
thanks
Mauro
time scheduling
- nightcrawler
Re: time scheduling
Hi see the wiki at: http://www.zoneminder.com/wiki/index.ph ... ZoneMinder
and this howto is also very informative: http://kotisivu.dnainternet.net/vuorris ... index.html
The best way to record is by setting it to Modect or MOCORD modus:
None – The monitor is currently disabled and no streams can be viewed or events generated.
Monitor – The monitor will only stream feeds but no image analysis is done and so no alarms or events will be generated,
Modect – or MOtion DEteCTtion. All captured images will be analysed and events generated where motion is detected.
Record – In this case continuous events of a fixed length are generated regardless of motion which is analogous to a convention time-lapse video recorder. No motion detection takes place in this mode.
Mocord – This is a hybrid of Modect and Record and results in both fixed length events being recorded and also any motion being highlighted within those events.
Nodect – or No DEteCTtion. This is a special mode designed to be used with external triggers. In Nodect no motion detection takes place but events are recorded if external triggers require it.
But If you want to use it like an timelaps video recorder you can use the RECORD function of an monitor. It's not possible to set an start or end time for the RECORD function. But it's possible to set the monitor function by making an script and run it like an CRON job on scheduled times.
see also this post for that: http://www.zoneminder.com/wiki/index.ph ... or_week.3F
How can I get ZM to do different things at different times of day or week?
Now you can switch between these two states by selecting them from the same dialog you saved them, or from the command line from issue the command zmpkg.pl <run state>, for example zmpkg.pl Daytime.
The final step you need to take, is scheduling the time the changes take effect. For this you can use cron. A simple entry to change to the Daylight state at at 8am and to the nighttime state at 8pm would be as follows,Code: Select all
0 8 * * * /usr/local/bin/zmpkg.pl Daytime 0 20 * * * /usr/local/bin/zmpkg.pl Nighttime
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
Re: time scheduling
Hi, thank for the answer,
It 'a shame that the software does not have this possibility.
Being able to choose when to enable or disable motion control functions do not think it impossible to manage.
Being able to monitor a place throughout the day without registering or recording at night to do so would be a very useful thing.
Maybe it's the only thing he lacks
- nightcrawler
Re: time scheduling
Well, you can make the function by following these instructions from the wiki so yes it's possible. And at my setup it works very good.
And I agree that and calendar function for turning ZM into an preset state like day,night or holliday mode would be nice.
But at the other end, why should you record an camera view when there is no action/movement....
Re: time scheduling
Sorry but in addition must be very interesting to have cameras that record and the other not? I think it is essential for the type of software, with this system that records all or nothing, for software of this magnitude seems to me absurd.
I hope in future releases
Re: time scheduling
Hello All,
The previous posts did hit the nail...
Indeed... why endless / useless recording (and viewing) if youll have Motion Detection capabilties on board?
Regards, Christo
Regards, Christo
