Page 1 of 1
ZoneMinder 1.25.0 and AxisMotionDetection
Posted: Mon Oct 10, 2011 6:49 pm
by sipi
Hi, I use some Axis cams and video server with AxisMotionDetection function. I used this HowTo for ZM 1.24.2. http://www.zoneminder.com/wiki/index.ph ... nDetection
I have a problem now because I updated my ZM to 1.25.0. AxisMotionDetection works but on Monitor View doesn't show last 10 events list. It shows table column header (ID, Name, Time, etc.) but doesn't list events. Of course on Main Page lists events (Hour, Day, etc.).
And missed some control on Monitor View, example Settings beetwen Scale and Close upper picture and Disable Alarrm bottom of left corner of picture and Force Alarm bottom of right corner of picture.
Is it bug or I made something wrong but I don't find any setup for these on Option?
Re: ZoneMinder 1.25.0 and AxisMotionDetection
Posted: Tue Oct 11, 2011 1:10 pm
by sipi
I do not understand what happened. Two days after suddenly appeared the event list, Disable Alarms and Force Alarm subtitle button. But Settings there isn't. I'm not changed anything I waited on advice of an expert.
What does it mean now? And where is the Settings?
