I recently installed a zoneminder server. During the build i had to use the next bug fix:
http://www.zoneminder.com/wiki/index.ph ... _libraries
FULL configure:
./configure --with-ffmpeg=/usr/local/lib --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=xxxxxxxxxxxxx --enable-debug=yes --with-webgroup=www-data --with-webuser=www-data --with-libarch=lib64 CXXFLAGS="-D__STDC_CONSTANT_MACROS -g -O3" ZM_SSL_LIB=openssl
Now if i look under options>images the top 2 options ( can_stream, stream_method ) are not available. Like show on
http://www.zoneminder.com/wiki/index.ph ... 211A_4.png
Any1 know a fix for this.
Kind Regards,
no mpeg recording
Re: no mpeg recording
The streaming options were moved to be bandwidth specific. They are now located in the Low, Medium and High B/W tabs.
mastertheknife
mastertheknife
Kfir Itzhak.
