Page 1 of 1
my root partition becomes full
Posted: Sat Oct 15, 2011 8:59 am
by juricac
hi! im wondering how zm fills the hard drive? where those files are stored? i didnt enable purged when full and my root partition became almost full, how can i find where the files are stored so i can remove them manually?
i uninstalled mysql and zoneminder to see if it helps but it still remains full, what can i do?
thanks!
Re: my root partition becomes full
Posted: Sat Oct 15, 2011 10:17 am
by PacoLM
You had to enable the purge when full filter. If you setup the percentage of disk you want to have full, ZM automatically keeps your disk void enough. If you didn“t change the default location of events & images, you could find them in /usr/share/zoneminder/events and /usr/share/zoneminder/images. THey are not deleted even if you uninstall zm.
To erase some unuseful files, install localepurge, it will free some space on disk. Also, in the /var/log directory, look for .gz files and delete them.
Hope it helps,
PacoLM
Posted: Sat Oct 15, 2011 10:32 am
by juricac
@pacolm hey buddy thanks for the clarification! it wasnt zoneminder problem thankfully i found files which populated root partition!
btw since i uninstalled zm 1.24.x could u tell me if i should go and install the lastest? im wondering if bugs that prevented cam from moving is fixed or should i stay with 1.24.x? thanks bro!
